wheel spacers? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 12-23-2013, 01:45 AM
Matt key's Avatar
Matt key Matt key is offline
Vehicle: 2012 Ram 1500
Trim Level: Sport CC
Color: Deep Cherry Red
Rep:25
Matt key is on a distinguished road
Default wheel spacers?
Well I finally ordered my SRT wheels today. Wondering if 1.5" wheel spacers are a good idea or not. Kinda concerned about how safe they are. I wanted the offset to be a little different instead of being sucked into the fenders like OEM style. Any opinions or pics? Thanks guys!
Old 12-23-2013, 11:25 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
I think you'll get mixed views on spacers. I personally have run them a few times in high performance street cars without incident. As long as they are hubcentric, and you check the bolts for the correct tightness regularly you should be fine. As for added stress at the hub, they won't be any worse than a wheel with the same combined offset as the SRT wheel and spacer.
Also, check your state's laws on the subject of spacers. Some states like Utah and Massachusetts deem spacers illegal..
Here is a highly recommended brand..
http://www.motorsport-tech.com/bora.html
295/60r20 Toyo Open Country AT Xtremes (previous tires were 285/65/20 BFG TA KO2s for 75k klms), Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 07-17-2014, 08:50 AM
burtonxrider21's Avatar
burtonxrider21 burtonxrider21 is offline
Vehicle: 2012 dodge ram 1500 sport
Rep:92
burtonxrider21 will become famous soon enough
I ran 2 1/2" hubcentric spacers from the link mentioned above with my stock rims and winter tires all winter and didn't have any issues at all! I put a little bit of blue Loctite on the studs when I installed the spacers just to make sure that they didn't come loose... In order to check the torque on them you would have to remove the wheel. When I removed them to install my summer tires again, I checked the torque on them just for fun and they were still at 130 ft.lbs.
