Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Power Wagon
Dodge Ram Decals
Old 12-23-2013, 11:41 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Default PW Recall
Alright, not limited to just PowerWagons, but recall none the less. Left tierod ball joint. Says it affects late 2009-2012 trucks. Mine specifically says the tie rod end will be replaced (no inspection, etc). Just curious if any of you have got it. I dont have the sheet in front of me for the recall number.
Just Got it, Give me time!
Old 12-23-2013, 02:34 PM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Power Wagon
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
I got mine in the mail Saturday I believe. I am at work at the moment so I don't have the paper in front of mine either. I didn't read through it just yet.
Old 01-27-2014, 01:17 PM
mopar06 mopar06 is offline
Vehicle: 2010 Dodge Ram Power Wagon
mopar06 is on a distinguished road
I got mine in the mail a few weeks ago. I just called two dealerships here in Jacksonville, FL, one of the service dept's didn't even pick up and the other one the service specialist said there was an 8 week back order on this part and took my name and number and said they'd call when the part was ready....8 weeks on recall part that has already caused multiple crashes and injuries???
Old 01-27-2014, 11:32 PM
BgDannyP BgDannyP is offline
Vehicle: 2013 Powerwagon
BgDannyP is on a distinguished road
I had the updated steering in my last truck, went through three sets that were all recalled. That picture is the left side tie rod end. Well known failure.. The angles in the steering put strain on this end, and if the tie rod doesnt travel perfectly flat you will snap off the shaft. There was a dent in the edge of the cup where it contacted the pin shown. Mine appears it was cracking for a while with progressive rust in the crack.
Old 02-03-2014, 11:50 AM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:59
glcarter will become famous soon enough
Made an appointment for my 2011 2 weeks ago. Took it in, the guy looked under the front and said I'll order the parts. Told him I thought it was a flat recall with replacement. He said there are 2 different tie rods one is fine, the other is the recall. Visually the difference is how the steering dampener is mounted. The recalled ones like mine are bolted to the tie rod, the non-recalled ones have a bolt that go through the tie rod in the fashion of a tie rod end. Told me they have over 30 ordered and only get maybe 1 in a week!
Just picking brains, mine's worn out!
Old 02-08-2014, 12:23 PM
Color: Granite
Rep:286
So I got my recall completed. I suggest you all get yours looked at. Mine turned into a nightmare!!
As they were seperating my left tie rod end from the knuckle for inspection it broke. Not pulling out of the socket, clean shear just below the threads! Rust shows the crack was already about halfway through the rod end. This leads to inspection of the the rest of the steering, long story short, lots of new parts.
New tie rod
New tie rod ends
New drag link
New drag link ends
New pitman arm
New drivers side knuckle
Thankfully my dealership did have all the parts in stock except the pitman arm (they fronted the cost for one at the local parts house). About 4 hours later I was back on the road. They didnt quite get the alignment right, but pretty damned close. Drives like new again, I didnt realise how much it had worn and got sloppy because it happened so slowly!
I doubt most of yours will be as bad as mine, but get the recall take care of. I wish I had got pictures, but my phone was in the truck (up on the lift). They kept all my old parts as a chrysler tech is on the way out to inspect them.
Old 02-14-2014, 07:39 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:67
steveschaedel will become famous soon enough
I have not received anything yet ???????????????????????
Old 02-19-2014, 02:18 AM
Iamahemi Iamahemi is offline
Vehicle: 2012 Ram Power Wagon
Color: PW7
Rep:58
Iamahemi will become famous soon enough
Try here. Select Recall information,enter your VIN
http://www.dodge.com/webselfservice/dodge/
2012 PW bright white,Leer cap,Bedrug,2010 rear headrest swap,black Mopar side steps, debadged
Old 02-20-2014, 09:20 AM
I ended up going to another dealership in Jacksonville and the service manager did the same thing with my truck...now just waiting for the call to take the power wagon in to get fixed...
Old 02-20-2014, 09:47 PM
Rep:67
My VIN came back negative for any recall items - anyone know why
