Old 01-04-2014, 10:01 PM
I push the skinny pedal
Rep:3277
I guess I should have been more clear, you have to trim from the tighter wound end, not the loose pig tail end on the progressive coils. You're right that the progressive side is the tighter coil, thanks for the clarification to an obvious error. All I was trying to say is that you can't cut from the loose pig tail or the spring won't seat properly and you'll cause issues.
Kurtis
Old 01-04-2014, 10:12 PM
Hornet Hornet is offline
Vehicle: 2013 RCSB Ram
Rep:470
LOL,i sorta wondered about your post,as you had me scratching my head for a minute
Rick
Old 01-04-2014, 11:05 PM
Rep:470
This is my basic formula for cutting linear springs,ie:stock front coils.
Once i know how much lower i want to go,i turn that measurement into a percentage number,that i then use to cut the springs.
This is a generalization for illustration purposes,so i'm using easy to work with numbers.
Say the truck measures 40" to the wheelwell arch,and i want to lower it by 2".
2" is 5% of 40".
So i want to cut roughly 5% off the springs length.
Cutting springs isn't an exact science,so i usually measure the diameter of the spring,then multiply that diameter by 3.14 (pi) to get a rough measurement of each coil.
Then multiply that number by the number of coils to get the rough overall length of the spring.
Once i know the rough overall length of the spring,i then use my 5% number to determine how much length needs to be cut off the spring.
Like i said,cutting springs isn't an exact science,but this will usually get you fairly close on the first cut of a linear spring
