servive fwd indicator? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 12-24-2013, 06:28 PM
joebud joebud is offline
Vehicle: 2012 ram big horn
Trim Level: big horn
Color: true blue
joebud is on a distinguished road
Default servive fwd indicator?
I was heading out today, stopped at my neighbors talked for a bit and went to leave. It was pretty cold today, when backing up I spun my wheels a little bit, put it in drive and in two seconds the service fwd light came on and the coolant temp on the display went to it's (default setting) 100 degree and the gauge went to zero. I drove to town about 20 miles everything else was working. I've been in two wheel mode this whole time. I shut the truck down re-fired it and it's been normal. Anybody knows what happened, did I dirty a anti-lock brake sensor, traction control, not spin the wheels enough? And what is the relation between the temp sensor and fwd service light.
Old 12-26-2013, 10:51 PM
DodgeV10 DodgeV10 is offline
Vehicle: 2015 Dodge Ram 2500HD
DodgeV10 is on a distinguished road
I have found out that the pcm on these trucks sometimes just need to be rebooted. And I mean shutting the truck off for a min or two and restarting. I just got out of my truck after finding out how to put the electric shifting transfer case into neutral. When I shifted back into 2wd the service 4wd light turned on. Its happened to me one other time after shifting out of 4low. I took it to the dealer right a way. But by time I got to the dealer and shut the truck off to talk to them, the pcm had reset and everything was normal. They thought I was . Now why the temp messed up with it is beyond me.
Old 12-27-2013, 10:38 PM
Color: true blue
Default Thanks for the response.
Thanks for your knowledge of this.
Old 12-29-2013, 09:46 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
did you check for a stored code?
