Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Dodge Ram Decals
Old 12-25-2013, 12:56 AM
sablefish's Avatar
sablefish sablefish is offline
Vehicle: 2013 ram sport
Trim Level: sport
Color: red
Rep:78
sablefish will become famous soon enough
Default 2013 sport with 8speed, will not go in park
MY 2013 ram sport with the 8speed trans wont go into park. I turn the dash nob and a service trans warning comes up on the screen and the truck would not shut off. I finally got the truck to shut down by holding in the start button for about half a minute. Now the truck is sitting dead at work, think the battery drained because the warning screen would not shut down and I had to go to work. Any one else have the problem of the 8speed trans not shifting into park?
2013 ram sport, 8 speed. pace edwards full metal jack rabbit tonneau, bed slide 1500cg bedslide, husky weatherbeaters
Old 12-25-2013, 05:08 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
Sounds like it's time for trip to the dealer. Things like that can get very frustrating huh?
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 12-25-2013, 07:31 AM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
yea I forseen that as being a big problem whit no manual lever to pull push ect
Bad deal ...
Old 12-25-2013, 09:08 AM
Monster5601 Monster5601 is offline
Vehicle: 15 Longhorn 3500
Color: Western brown
Rep:483
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Bad deal ...
Even if you had a console shifter, it is still electrical. They done away with mechanical linkage for sometime now.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 12-25-2013, 09:22 AM
OldJoe OldJoe is offline
Vehicle: 2013 Ram 1500 Quad Cab, 8sp
Trim Level: BigHorn. RamBox
Rep:217
OldJoe has a spectacular aura aboutOldJoe has a spectacular aura aboutOldJoe has a spectacular aura about
That's correct, Monster.I have heard of a couple of the switches on the rotary going bad. It makes me nervous because I don't know anyway that you can bypass it to get home if it happens. I do think it is important to put it in park before shutting off the key, even though there is an override that automatically shifts it out of drive to park. A couple of times in the beginning I forgot to first put it in park and it seems to really hesitate before it does its auto thing. I get the distinct feeling that it doesn't like it when I forget!
Old 12-25-2013, 11:24 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:491
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
Sounds like there is some physical problem in the trans, that is preventing the park pawl from engaging (or a bad Park sensor, that thinks the pawl is not engaged when it really is). Your dealer should be able to take care of it for you. Not a common problem, but I understand your frustration! Sorry for the hassle you are having!
Old 12-25-2013, 11:58 AM
sablefish's Avatar
Trim Level: sport
Color: red
Rep:78
Brought my code reader with me to work today. P0850 park neutral switch. Any one know if this can be bypassed. Can I put a jumper wire on it. Where on trans is it located. It is an 1.50 hour tow to the nearest dealer. Thanks.
Old 12-25-2013, 01:23 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Rep:1543
I would really think about doing anything to your truck. You don't want to get in a situation where your dealer calls VOID because of what you did. It sucks but better to have it fixed and have it hauled to the dealer on their dime.
Old 12-25-2013, 02:19 PM
Vehicle: N/A
Rep:491
P0850, if I understand correctly, is an engine fault code. You should also check for TCM faults (which you probably can't do with your scan tool). There should be some other (TCM) faults that indicate in more detail exactly what the problem is.
Old 12-26-2013, 02:02 AM
Thunderhorse's Avatar
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:763
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
Interested to hear what you find out.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
