Old 12-26-2013, 02:44 AM
01Survivor's Avatar
01Survivor 01Survivor is offline
Vehicle: 2008 Ram 1500
01Survivor is on a distinguished road
Default Loss of Power
(Newbie ? here)
I have a 2008 4x2 5.7 hemi with a Procomp 6" lift on Toyo Open Country AT II (35x12.50x20). It feels like I have lost some of the get up and go that it had prior to the lift. Am I imagining this or is this a usual occurrence when trucks get lifted? Is there a way to restore the quickness I think I have lost by changing gear ratios, exhaust, adding a Bully Dog system?
Thanks
Jamie
Old 12-26-2013, 12:13 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
If you went w the bigger tires at the same time, that's part of it. Larger diameter contributes to a greater moment of inertia, heavier tire too. Another part of it is that the truck is higher and is blocking more air. They already had the aerodynamics of a slanted brick. But now you've leveled and lifted that brick six inches higher. And something else. Your suspension components are now longer and that creates a greater moment of inertia due to greater flex.
Re-gearing it is the best way to get that performance back. A tuner is a cheaper way of changing the shift points..
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 02-03-2014, 04:32 PM
01Survivor's Avatar
i finally bought a new gear and went with the motive 4.56 and also picked up a 180 degree thermostat. I won't be home until mid march, but my parts will be there... lol
Old 02-03-2014, 05:35 PM
huff73541 huff73541 is offline
Vehicle: 2007 Ram 1500 Big Horn
huff73541 is on a distinguished road
go for a superchips tuner...I did that with intake and exhaust and it has a lot more get up now after lifting and 35's, but gearing would be the best option i would think
Old 02-06-2014, 07:36 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
exactly
youre gunna loose your power because of the tire weight my friend. get yourself a chip to bandaid the problem (which i did) or spoon out the cash for some gears and it will be a whole new beast
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
