Old 12-26-2013, 11:10 PM
Big Red Horn Big Red Horn is offline
Vehicle: 2012 dodge ram
Big Red Horn is on a distinguished road
Default uconnect not working correctly
Hello fellow ram owners,
My ram has the RES radio. I have no idea was uconnect version I have, but here's the problem. I pair my cellphone (Samsung) up to the uconnect and it works fine for about a day or two. When my wife calls the music will turn off and the radio says incoming call like it suppose to. After a day or two my wife will call and nothing will happen. I only can receive the call using my cellphone. I then will have to pair the cellphone to the radio again. Has anyone else had this problem?
Old 12-26-2013, 11:35 PM
Rep:2620
does your RES radio have the phone hard key ?
if it does that is the RES 130s
the one without the phone hard key is the RES 130
they use different Uconnect modules, uconnect was just an after thought on the one without the hard key
the RES 130s uses the same external Uconnect module as the REN, RBZ, & RHB, , if i recall correctly
The RER & RHR both have an internal Uconnect module
I know this doesn't help with your intermittent uconnect issue, but it gives you a bit of background
your issue MAY be a setting on your phone, i don't know much about smart phones & the settings
Old 12-26-2013, 11:49 PM
Yes it has the phone hard key, so it must be the 130s. The phone is a regular phone. My wife (boss) will not allow me to get a smart one. Thanks for the information.
Old 12-27-2013, 12:10 AM
DodgeV10 DodgeV10 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Tradesman
DodgeV10 is on a distinguished road
I don't have a Samsung but it sounds like a phone problem. I had a phone with a aftermarket radio with almost the same problem. It was a setting in my phone. Do you have the auto Bluetooth connection on under the settings? If its off it may not pair with the radio everytime. Or maybe your Bluetooth goes into a power saving mode. Check your owners manual for your phone. I hope that helps.
Old 12-27-2013, 01:21 AM
Edokdyshi's Avatar
Edokdyshi Edokdyshi is offline
Vehicle: 2012 Ram 1500
Rep:143
Edokdyshi will become famous soon enoughEdokdyshi will become famous soon enough
I too am have many issues with my uconnect. I have the RHR and an iPhone 5s. Sometimes calls wont go thru, sometimes the music won't go thru, and sometimes it freezes the radio to the point I have to shut the truck off and let it sit for 5-10 min.
18" Magnaflow muffler, 5% tint all around, multiple blacked out parts, de-badged, Westin Bull Bar, K.C. Long Range SlimLites
Old 12-27-2013, 05:30 PM
Thanks to the both of you. I will check my phone settings.
Old 12-30-2013, 09:25 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Try rebooting the phone by removing the battery for a couple minutes and then reinsert it. Give this a shot.
Also when this issue occurs, if you press the Uconnect phone button, what happens?
Old 12-30-2013, 11:23 PM
I'm will check tomorrow and see. Thanks. On a different note, how do you put quotes in?
