Rear window defrogger install - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 12-27-2013, 07:04 PM
DevinC's Avatar
DevinC DevinC is offline
Rep:193
DevinC has a spectacular aura aboutDevinC has a spectacular aura about
Default Rear window defrogger install
Hey guys, I'm currently in the process of installing a rear window defogger on my 2013 reg cab 1500. (I went with frostfighters universal truck kit. I haven't used it yet, so I am not endorsing it). I have already installed the heating elements and buss bars on the window.
Since you guys like pictures, here are the heating elements already installed:
(My windows are currently not tinted. Tomorrow morning I have an appointment to get them tinted.)
Never again will I install one of these. With all the careful triple measuring and trimming it took me about 4-5 hours. I probably took longer then needed but I wanted it perfect, and I am extremely happy with the install.
Anyways, my question is the wiring. I have everything routed out and connected but I need to find "a positive wire that is activated when the ignition switch is turned on". From searching the forums, I read that I can use the passenger side cigarette lighter socket wire. Is this correct and/or is there a better place to tap into "a positive wire that is activated when the ignition switch is turned on"?
Thanks.
Old 12-27-2013, 08:21 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Nice install, reps to you for sharing, as for the tap, I would run a wire up to the front and tap into the fuse box, use one of those fuse taps. JMO
Something like this, I have used one for my Air pump, they work well, just need to find the right place to tap where it only provide 12v when the truck is running.
http://www.ebay.ca/itm/2pcs-New-Add-...item3a893e0e5b
Old 12-27-2013, 08:31 PM
DevinC's Avatar
Rep:193
Thanks Asur, the kit does use one of the fused tapped wires. I just need to know which wire to tap into. Since the kit is universal, all the instructions say is to find that 12v wire... I am new to Ram trucks and have no clue which wire from the fuse box to tap into. Sounds dumb, but I don't want to mess anything up.
EDIT: The kit uses a fused wire not a fuse box tap that you linked. I like that fuse box tap, but I don't feel like waiting a week to get it. Local stores only have it supporting up to 10amp, but I need it to support 20 amp. So can I tap into the passenger side cigarette lighter socket?
Old 01-03-2014, 04:03 PM
DevinC's Avatar
Rep:193
Default Rear window defogger install
Just to give you guys an update:
I tapped into the cigar lighter socket (drivers side) and the unit powered up with no problems. I haven't driven the truck yet with a fogged up rear window due to my schedule and hot Miami days. But I did have to turn the unit on to test it, and it made the window hot! I can't wait to use it when the window fogs up.
And thanks for the reps Asur.
Old 01-13-2014, 10:40 AM
DevinC's Avatar
Rep:193
It's been over a week and I have used this a number of times now. It works flawlessly. I have absolutely no problems. I will post a picture later of where I installed the ON/OFF switch.
Old 01-22-2014, 11:01 AM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Color: Blue
Rep:28
TurboCup87 is on a distinguished road
Thanks for the info!
