Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
MOPAR DECALS
Old 12-29-2013, 03:06 PM
Trober's Avatar
Trober Trober is offline
Vehicle: 2006 Dodge Ram 1500 4.7L 2WD
Trober is on a distinguished road
Default The notorious engine tick!
Ok so some people have said lash adjusters then another says chain guides and tentioners or a spun main bearing. Which is it lol? My 06 ram 4.7 has the tick and it's on start up, but then goes away after warms up or has been drove around the block then is quiet as a mouse. To me the noise is more Hurd from under the truck like its a main bearing. I've never Hurd of a main bearing that stop ticking or rattling after warm up ect, they've always stayed rattling and has loss of power. The truck runs like new no loss of power ect, so I'm leaning toward the lash adjusters or chains! I just need some good sound proof or help here lol I'd hate to change adjusters and that not be it. The truck has 103k ive only putt on 6k though I'm the second owner so idk how the other person did maintance but I change it every 3k or sooner. Thanks for any opinions in advance!
Old 12-29-2013, 03:29 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Possible Exhaust manifold leak, broken stud. Been there, done that.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 12-29-2013, 03:36 PM
Trober's Avatar
All the bolts are still intact and tight I haven't tried to feel for leaks though. I just figured the lash adjusters finally pump up once it warms a little maybe there's some sticky ones.
Old 01-01-2014, 10:40 AM
Matts 08 4.7 4x4 Matts 08 4.7 4x4 is offline
Vehicle: 2008 ram big horn 4.7l 4x4
Trim Level: Big Horn Club Cab
Matts 08 4.7 4x4 is on a distinguished road
My 08 with 50k has a click/tap noise at idle, valve lash top end, needs more oil pressure at idle to fill the hollow cams and other lube points, sound goes away once the engine is reved. I know you said it sounds like it could be coming from bottom end, well lets hope not (piston wrist pin)
Old 01-20-2014, 09:02 AM
djm2009 djm2009 is offline
Vehicle: 2006 dodge ram 1500 4x4
djm2009 is on a distinguished road
I have an 06 that does the same thing. The ticking is very low and you have to listen for it. After running for about a minute it goes away. I have only had it for one oil change (and changed it 1000 early). Going to try M1 next and see if that does anything. mine has 63000 + on it.
Old 01-20-2014, 09:42 AM
Trober's Avatar
I'm 100% certain it's the lash adjusters that are sticking till it pumps up a little just to lazy at the moment to do it lol plus it's my every day driver so I can't have it down!
Old 01-21-2014, 01:41 AM
Bryce204 Bryce204 is offline
Vehicle: 2002 Dodge Ram 1500 Quad Cab
Color: Forest Green
Bryce204 is on a distinguished road
Engine was ticking for me on cold start.. It was the exhaust manifold
2002 Dodge Ram 1500 SLT Quad Cab
Old 01-21-2014, 07:10 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
My 03' has been doing that for at least 5 years, love to know what it really is.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 10-31-2014, 03:02 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
The early Gen 3 Rams are notorious for breaking exhaust manifold bolts. Take a good flashlight and really look around, especially at the lower bolts. Chances are you have a broken one.
Old 10-31-2014, 03:39 PM
Trober's Avatar
Nope wasn't the bolts or gaskets! Replaced all lifters, exhaust manifold gaskets and bolts and still does it. Still think it's the chain tensioners.
