Old 12-29-2013, 08:22 PM
knightmoves's Avatar
knightmoves knightmoves is offline
Vehicle: 2006 dodge ram 1500 slt
Color: silver
Rep:42
knightmoves is on a distinguished road
Default bushing removal
I have just bought a set of new upper and lower control arms. I also have bought a new set of poly bushings too. and one got tips on how to remove the upper control arm bushings? I see the bolt bar in the arms and was wondering how to go about removing the bushings with out messing the arm up.
I was nice to a chevy guy once..... I chained him to my bumper so he could keep up!
Old 12-29-2013, 08:50 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
You could buy a bushing removal kit, but if it were me I would lok for a local shop with a big assed hydraulic press and have them remove the old and install the new bushing for me.
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau* Iron Bull Fr. bumper with custom Line-X coating* Lumens HID low beams
Old 12-29-2013, 09:38 PM
Color: silver
Rep:42
I have a press. I'm just trying to find out how to press them out from around the bar.
Old 12-29-2013, 11:39 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
Heres a quick link. Unrelated vehicle but you'll get it no problem
Link
Old 12-30-2013, 10:14 PM
Color: silver
Rep:42
Link
that helps a little but How to remove the bushings with the bolt in place!!!???
Old 12-31-2013, 12:47 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
Failing this, how about a scalpel?
Old 01-25-2014, 06:33 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Burn the OEM Rubber out thusly
A common technique is to literally burn out the OEM rubber bushings. The metal parts (bushings, pins, sleeves etc) will not be damaged but may discolor. Just repaint them and grease the bolt threads.
Post up some photos of the parts, and we'll help with the press procedure.
In this photo (the smoke is TOXIC) we took a stout piece of aluminum and put a little puddle of lighter fluid to the c-arm contraption and melted/burned away the OEM rubber.
