ZDOG
Old 12-29-2013, 08:34 PM
blee1ash blee1ash is offline
Vehicle: 2012 Ram 1500
blee1ash is on a distinguished road
Default Stiff Power Steering?
When first starting my tuck when it is really cold the power steering is really stiff for just a few seconds. Has anyone else experienced this? Just wondering if this is normal or if I have a problem starting. I'm guessing it is just because of the extreme cold.
Thanks.
Old 12-29-2013, 08:48 PM
Asur Asur is offline
Vehicle: .
Rep:4373
it was down to -22 last week and it did this to me once, it was like the steering was stuck and then a few seconds later no problem, was fine all day, has not done it again since. This week supposed to be -28 so will try it again and report back if it does it again.
Old 12-29-2013, 09:26 PM
Sounds like the same thing mine is doing. Only lasts a second or two, then is fine.
Old 12-29-2013, 09:47 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
every dodge i have had i replaced the ps fluid with synthetic and no more problems. when it is cold the pressure build up from dino fluid must be tremendous and a lot of chrysler products get leaking hoses from that.
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 12-30-2013, 02:39 PM
Trim Level: sport
Color: green
Rep:682
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
have had that on our 04 grand cherokee. doesn't get to the low temps azur gets though.
Old 12-30-2013, 02:45 PM
Vehicle: .
Rep:4373
Think this will be a project this summer and replace whats left in dyno fluids with full synthetics.
Old 12-30-2013, 07:02 PM
dbuzz77's Avatar
Color: Stone White
Rep:100
it only takes 10 min. suck your reservoir dry with a suction pump and add up to the line. do this again in a month and it will all be clean. you will notice the difference after the 1st time.
Old 12-30-2013, 08:34 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Maybe do this:
1) Start truck & check for PS stiffness.
2) If problem is detected, drive truck in a southerly direction until problem disappears.
