6.7 just dies on me HELP!!!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 12-29-2013, 10:12 PM
tmccue tmccue is offline
Vehicle: 07 Diesel 3500
Color: silver
tmccue is on a distinguished road
Default 6.7 just dies on me HELP!!!!!
I have a 2007 6.7 3500 I have been having an issue with the truck just dropping power while drivinging and when I finally slow down the truck will just turn off. This is not good cause my steering goes out while moving. If I try and start the truck again it will just crank and crank and finally if lucky it starts right up. I have only got an engine code once from this (p1011 unknown code). I'll list mods in case it's caused by one but this has been happening randomly. I had about 3 months where this hasn't happened but it came back today.
Mods are - DPF delete, EGR delete, sinister throttle delete, sinister fuel plug, arp head studs, H&S mini max, 4"dp, 4"straight pipe to stacks.
Please if anyone has some thoughts let me know. I'm thinking the fuel is dropping off but cant see any odd numbers on the tuner show up.
Old 12-30-2013, 09:26 AM
brandenm brandenm is offline
Vehicle: 1998 dodge ram 1500
Trim Level: slt laramie
brandenm is on a distinguished road
If i recall correctly, my boss had a 1999 with same motor, come to find out, it has a secondary pump on it (pickup) your tuner won't acknowledge that pump.
Old 12-30-2013, 09:08 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
99 would have a 5.9l 24v cummins. Much different from a 6.7l.
Check your voltage to your batteries and alternator and connections.
IG:@briley59
Old 12-30-2013, 09:20 PM
vtram vtram is offline
Vehicle: 2010 ram 2500
Trim Level: st
vtram is on a distinguished road
When was the last time you changed your fuel filter?
