Old 12-30-2013, 09:16 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Default Walter's new engine + extras
Well, Walter the van needed an engine overhaul. He was leaking oil from all over. I went in and just rebuilt the engine with the exception of the short block. I installed a cloyes double roller timing set and advanced the cam 2 degrees, so I have a slight increase in compression thus higher CO2 which means less O2 to the sensor = more MPG.
I got an enginetech seal kit, very nice set. Graphite head gaskets with stainless steel fire rings. Etc... Installed new tensioner, drive belt, O2 sensor, ECT sensor... All new seals. I went in and rebuilt the lifters. The lifters were all seized internally, but I got them rebuilt. OH, I had to replace the passenger side exhaust manifold, because the EGR valve bolts snapped inside the manifold and so did my bolt extractor.
I used anti-seize on all the exhaust bolts and replaced the stock hardware with all stainless steel.
I removed the catalytic converter and installed a thrush turbo muffler, sounds nice, but does quiet down at cruise.
After assembling, I went to fire it up and eventually got it to start, then I set the fuel sync with my MT2500.
After a couple hundred miles on the engine I put Mopar Combustion Chamber cleaner in to burn out that carbon in chambers.
I also flushed the cooling system a few times over the course of days, and I eventually did put new coolant and distilled water in...
Now, I just need to rebuild the front end steering and suspension, do the rear brake disc upgrade conversion kit, replace the brake master cylinder.
I also installed a maradyne dual electric fan 7 months ago.
Here are photos of the engine work.
Cloyes Timing Chain Installed: http://tinypic.com/r/11w4hl4/5
Timing Chain Case Cleaned and Installed: http://tinypic.com/r/wwao9s/5
New Viton Valve Stem Seals Installed on freshly cleaned and lapped heads: http://tinypic.com/r/t9k67l/5
Rebuild Head Deck Side: http://tinypic.com/r/5kk0fa/5
Cleaned and installed plenum pan: http://tinypic.com/r/zlwv9l/5
Cleaned push rods and plenum pan: http://tinypic.com/r/24flm44/5
Rebuilt lifters: http://tinypic.com/r/k3swmx/5
Cleaned and rebuilt intake manifold with some new sensors and new injector seals etc: http://tinypic.com/r/28w2gpy/5
Heads installed: http://tinypic.com/r/2hceyyb/5
Manifolds installed: http://tinypic.com/r/14ukhfq/5
Tada: http://tinypic.com/r/ic0n08/5
New O2 sensor: http://tinypic.com/r/jtow93/5
My small tool box: http://tinypic.com/r/4faxu/5
Old 12-31-2013, 04:47 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Pretty cool. You mind me asking how much you have into the rebuild?
Old 12-31-2013, 04:56 PM
ramvan2500's Avatar
Rep:128
I did not sit down and add everything up, but if I had to guess I would say about 350-400. If it was not for the exhaust manifold then the cost would have been 90 less.
I will tell you that the thing pulls allot better in all speed ranges. The trick is to reset the computer to factory so it can relearn all the new parameters.
I have to run synthetic though, conventional oil seems to break down prematurely. For now I have conventional installed, but once it is time to change the new oil I'm going synthetic.
Old 12-31-2013, 05:00 PM
ramvan2500's Avatar
Rep:128
Oh yea, the new plenum gasket is already leaking a little. Eventually I am going to get the huges kit to fix that. Or, I will just replace the entire manifold with the MP one. I'm more likely to get the huges kit as I am always poor.
Old 12-31-2013, 07:25 PM
Rep:326
That's pretty sad that the new plenum gasket is leaking already. I highly recommend the Hughes kit though. I was really pleased that it came with everything necessary except loctite and the fuel disconnect tool.
Old 12-31-2013, 08:15 PM
ramvan2500's Avatar
Rep:128
Yea it is sad. The gasket kit I bought included the updated plenum pan gasket. I was hoping to get by for a little while before it would start to leak, but I knew the risks. Anyways, the leak is so small. The kit certainly is inexpensive also.
