Old 12-31-2013, 11:54 PM
ChrisTM ChrisTM is offline
Vehicle: 1998 Dodge Ram 1500 4x4 5.2L
ChrisTM is on a distinguished road
Default P0720 after clearning throttle body?
Sorry if this is in the wrong spot I wasn't sure where to put it and this was my best guess.
Truck is 98 Ram 1500 4x4 with about 48k miles on it.
Long story short, my mothers POS trailblazer was having throttle body problems and it needed cleaning. I get the brilliant idea that since I am doing one, I might as well do mine while I am at it.
Immediately after I start the truck and move it out of my way and I get a CEL. I check it thinking I missed something and everything looks right, but I get code P0720.
I am comfortable replacing the sensor, but the rub is I got this code when I first installed the air intake. I don't believe it's the sensor but I could be wrong. Any thoughts?
Old 01-01-2014, 01:28 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
I think one of the sensors you hit on the intake shares the same ground with the sensor for that code. Check to make sure you don't have any loose pins or anything. No reason a sensor should fail after throttle body cleaning. Unless...You used a non-sensor friendly cleaner.
Old 01-03-2014, 02:19 AM
I think you're right, I didn't think about the ground sharing. Also I noticed I no longer have a grounding strap from my engine :/
Old 01-03-2014, 02:26 AM
ramvan2500's Avatar
Rep:128
Make sure you double check all your grounds. If the engine isn't grounded then it won't run properly. If at all.
