battery not charging - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 01-01-2014, 08:30 PM
dschutz1979 dschutz1979 is offline
Vehicle: 1987 dodge d150
Trim Level: le 150
Color: red and white
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
dschutz1979 is on a distinguished road
Default battery not charging
I have 14 volts coming out of alternator. But when I test the battery with the engine running it shows the battery to be almost dead. Any ideas? I'm starting to think something is wrong with the wire. Can I just run another wire from the alternator over to the battery?. The.engine just shut off and I finally found out its was the ground going from the engine to the firewall. And when I fixed it this problem come up. I'm getting desperate and fed up. The alternator, battery and voltAge regulator are all new.
Old 01-01-2014, 09:25 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Your truck is pretty old, the old wire cold be bad. Check it with a continuity tester/multi tool. If you get 0 ohms, it's shot. Replace it with a new wire of at least the same size wire. I'm a boatbuilder and we always use tinned copper marine grade wire.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 01-01-2014, 11:11 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
check the battery voltage, truck not running. look for the same voltage on the alternator. if the battery voltage isn't at the alternator, it won't charge. follow the wires to the battery to find out if the alternator is connected properly.
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 01-02-2014, 11:35 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Check the fusable link coming off the battery (positive) along the driver's fender. Look for a wider section of the red wire to locate the fusable link. There should be 3 if I remember correctly. The fusable link is a lead-core section of wire that is designed to fail if there is an electrical failure. Such as losing the body-ground to the firewall.
Check the wires for breaks and replace it if you find one.
Old 01-02-2014, 01:34 PM
DodgeAddict's Avatar
DodgeAddict DodgeAddict is offline
Vehicle: 9 trucks form 77-97
Trim Level: SS/T Adventurer SE
Rep:42
DodgeAddict is on a distinguished road
Check the ground from the battery to the body If your blower motor is acting up (dragging) It will blow 2 possible fuse links causing a no charge condition
My wife says I'm addicted to Dodge I have the CCDD chromosome in my DNA It's genetic!
Old 02-26-2014, 02:30 PM
RYAN1991 RYAN1991 is offline
Vehicle: 2005 Dodge Ram 1500
RYAN1991 is on a distinguished road
I have a 2005 Ram with similar issues, and my blower motor will only run on the highest setting. Could this be the same issue?
Old 02-26-2014, 02:38 PM
Vehicle: 95
Rep:1776
Yours is an '05 so there's a completely different system. In my experience, the '05 is usually the blower motor itself to be at fault.
Since your's is a 3rd Gen it may be best to start a new thread or add to an existing thread under the 3rd Gen section, heating and cooling if a search doesn't return any helpful results.
I did a search for "05 blower motor only works on high" and this is what came up:http://www.ramforumz.com/search.php?searchid=3641492
There should also be a small thermal relay under the passenger's side of the dash that may be faulty.
Old 03-12-2014, 10:52 PM
vdubs63's Avatar
vdubs63 vdubs63 is offline
Vehicle: 2001 Dodge Ram 1500
Color: White/Grey
vdubs63 is on a distinguished road
I have a 2001 Ram 1500 and it's doing a similar thing. I had a bad alternator so I replaced it with a new one from Auto Zone. I thought everything was fine but about 5 minutes after driving it the battery charge level dropped to zero and the Check Gauge light came on. I thought maybe it was a loose wire or something that caused it to do that but a little while later my dash cluster just dropped to zero on my way home. I got home and pulled out the voltage meter and the battery wasnt even charging. I pulled the positive lead and it just killed the motor. My alternator fuse is in good shape and I have looked at all my grounds and they are all in good shape, not rusted or corroded at all. I'm kind of confused at why this is happening. I have seen on some other posts where people said their blower motors wouldnt work or would only blow on high, and I do not have that problem. Why isn't it charging?
Old 03-12-2014, 11:35 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:255
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
How old is your battery? Have you had your battery load tested? This winter has been very hard on batteries all over. I don't have a lot of faith in the new cheap out style of battery post connecters that are used on todays vehicles. I have changed my connecters to marine grade battery connecters and I have a lot more faith in having a good battery connection.
Old 03-13-2014, 08:52 PM
vdubs63's Avatar
Color: White/Grey
Today I went and exchanged my alternator for another one and I also bought a new battery because my old one was shot. My battery reads 12.40 just sitting there and it reads 11.90 while running. I went to take it around the block right after I put in the new stuff and the Check Gauge light came back on and the Charge Gauge went to the red line. I checked my cables and fuses and they are all ok. I'm have run out of ideas of what could potentially be wrong.
