Old 01-03-2014, 05:15 PM
Gossamer Gossamer is offline
Vehicle: 2012 ram
Trim Level: laramie
Color: green
Rep:12
Gossamer is on a distinguished road
i'm looking at running a 285/65 or something comparable. Like I said, nothing extreme.
I'll have to think more on the other mods that truck has...as it's not really part of my question, I'll save it for another thread.
I appreciate your thoughts and can see what you're saying. Thanks for responding. Really is appreciated.
Old 01-03-2014, 05:47 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
Okay, so nothing huge... MT or AT? There's obviously a difference in weight between the two which will effect it. You'll probably be okay running the spacers, just be sure to check them every so often. I would pull the wheels off every couple thousand miles and check the spacers and retorque them. That way you have a good idea of what kind of shape they're in and how they're standing up. It's possible the set up will work for you and is so, good on ya... But if not be prepared to pull them off and possibly replace wheel bearings and such.
No problem man! That's what a forum is for. Good discussions like this always yield learning and a better understanding of what's going on for both sides. Questioning ideas or concepts is never a bad thing in my book, you learn a lot from it.
Old 01-03-2014, 06:14 PM
Vehicle: 2012 ram
Trim Level: laramie
Color: green
Rep:12
Most likely AT...I don't like to listen to the hum of tires like I used to with my Jeep.
Old 01-12-2014, 09:28 PM
Vehicle: 2012 ram
Trim Level: laramie
Color: green
Rep:12
So, I did some more research and found something that was more scientific...it supports, to some degree, my initial thoughts and those I've read since I started this article. In any case, this might be beneficial for the rest of you who were wondering.
http://www.maximummotorsports.com/te...s_spacers.aspx
Old 01-12-2014, 10:56 PM
mygt8a4re's Avatar
mygt8a4re mygt8a4re is offline
mygt8a4re is on a distinguished road
Hahah, thats great, that article has been on the maximum motorsports website for years. I remember seeing it years ago when I purchased some of thier suspension parts for my mustang....as I mentioned in my last post, I have used them on a few vehicles problem free. I never purchased cheap pieces, only high quality parts. I had a pair on the rear of my first mustang that was putting around 400hp to the wheels and I was running drag radials. Ran them for about a year before I went totally drag and purchased different wheels....
MYGT8A4RE = My GT Ate A Ferrari, been using that screen name for years....
Old 01-13-2014, 12:51 AM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
Got a question about clearing the wheel studs.
Would a 1.25" wide wheel adapter clear the studs? I really don't need anything wider for the wheels I want.
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
Old 01-13-2014, 11:29 AM
Vehicle: 2012 ram
Trim Level: laramie
Color: green
Rep:12
Default hmmmm
So, here's my issue...if you can run 400hp on a car with adapters and others race with them, I have to imagine the stress on a truck can't be more unless under serious load. I don't tow anything appreciable and don't off-road ever. I'm not trying to talk myself into this or out of it but I'm still waiting for some "real life" issues to crop up. I saw the video earlier in this post but can't use one instance as my predominant decision maker.
I spoke with a local truck shop who does a ton of dealer work and he says they put them on "all the time". Not to mention, dually's come with them from the factory, in some cases. AND, in my research, there is an entire market for commercial vehicles, some of which are diesels that haul crap all day long. IDK, this is tough. I think I'll send it to myth busters. They'll test it right.
Old 01-13-2014, 11:54 AM
mygt8a4re's Avatar
Heheh, the real world tests would show the cheap inferior material pieces to fail and the quality parts to hold up fine. Back when I had started using them I never heard any horror stories and knew several people using them for different reasons on different vehicles. It wasnt untill the last set I used and while on topic of adapters at a forum, that I heard a couple people posting "beware, your wheels will fall off". If you buy cheap, low quality pieces maby you will have a problem...you get what you pay for, cheap isnt always better...
