N Fab step modifications? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-04-2014, 03:18 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
When I had mine, I felt they were quite sturdy and would not be of issue
Only had them for 2 months till I switched to AMP steps.
But I would not hesitate to grab them again
sales@revelperformance.com
Old 01-04-2014, 03:21 AM
jrosandich88's Avatar
jrosandich88 jrosandich88 is offline
Vehicle: 2014 Ram 1500
Trim Level: Express Quad Cab 6.4
Color: Max Steel
Rep:13
jrosandich88 is on a distinguished road
Any specific reason for switching to the AMPs?
Old 01-04-2014, 03:37 AM
Revel Performance
Rep:1804
My truck was too tall and my kids then were smaller. The amps do drop about 7-8" which is substantial.
Plus I liked the clean look when they tucked away.
But again, if I did not have the amps, I'd still be rocking the NFabs.
If you do need a set, let me know and I can get them to you
fastNugly@bullysperformance.com
Old 01-04-2014, 10:48 AM
noco1500 noco1500 is offline
Trim Level: Outdorrsman
noco1500 is on a distinguished road
I just mounted them this evening and I did notice that they sit tight on the front flares. Mine are just stock but I was concerned about it. What exactly happened to your flares and what are they getting you for on new ones if you don't mind me asking?
The passenger side front flare bowed out at the bottom where it meets up with the NFAB step. Warping flares is a pretty common problem so the dealership didn't think much of it and just ordered a new one under warranty. When their body shop guy was replacing it he said the step was part of the problem but they went ahead and covered it. The steps are off the truck now I think I just need to tweak them a bit so they drop about 1/4 of an inch further. I don't want them hanging down too low or it will look like crap since the NFAB kind of simulates a rock slider type look.
Old 01-04-2014, 02:33 PM
Color: Max Steel
Rep:13
I agree I was concerned about getting them as tight to the body as I could without actually touching the truck. The front if the steps on both sides are just barely making contact with the plastic at the bottom of the fenders. I wasn't sure if that would cause problems or not since all pressure would be downward away from the contact point and again the contact is just very slight.
Old 01-06-2014, 01:15 PM
RandyW's Avatar
RandyW RandyW is offline
Vehicle: 2017 Ram 1500
Trim Level: Rebel
Color: Blue Streak Pearl
Rep:156
RandyW has a spectacular aura aboutRandyW has a spectacular aura about
I had them on my Tundra for about 2 years until I sold the truck. They were very sturdy and I never had a single issue with them. I was concerned about them not having end caps, so I asked n-Fab about that before purchasing. I don't remember their exact response, but they said something about it being possible to have moisture trapped inside when using end caps (thus causing rusts, etc.). I never had one spot of rust or paint chipping on mine. I'll be ordering the regular cab lengths, or the n-Durasteps here shortly for my Ram.
2017 Ram 1500 Rebel Edition, Blue Streak Pearl, 4x4 Crew Cab
Old 01-07-2014, 08:00 PM
Dave665's Avatar
Dave665 Dave665 is offline
Vehicle: 2012 Dodge Ram 1500 Quad Cab
Trim Level: Sport 4x4
Color: PX8 Black
Dave665 is on a distinguished road
I went with the wheel to wheel n-fabs, used hardware they supplied. As for the opened ends, to keep out snow, mud etc. I taped off the outside ends with newspaper and painters tape to protect the finish , filled the open ends with some spray foam insulation. Let it dry over nite, then cut it off flush the next day and finised with a couple shots of black spray paint.
Old 01-07-2014, 08:42 PM
Color: Max Steel
Rep:13
Thanks for the advice. I actually like that idea, I figured to get those covered I would have to get a little creative and that seems to be one of the better options because that should work to keep most if not all of the moisture out of the tubes. Have you had any rust/finish issues at all?
Old 01-07-2014, 09:15 PM
Revel Performance
Rep:1804
Very smart idea!
When I had mine is was like WTF? Really? No caps
Perfect solution to capping it off
Old 01-08-2014, 12:48 AM
Dave665's Avatar
Color: PX8 Black
No rust issues ,no problems with the finish. Just keep spray foam off the front finish till it dries up.
mod, mounting, nerf steps, nfab
