Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 02-16-2012, 01:22 PM
Toon tugr's Avatar
Toon tugr Toon tugr is offline
Vehicle: 2005 cummins & 2010 5.7 Hemi
Trim Level: 2005 & 2010 are SLT
Color: 2010 Silver, 2005 Burgundy / silver
Toon tugr is on a distinguished road
Question Trailer Brake controller adding the factory option?
I am wondering if the wiring is already preinstalled behind the dash for the factory trailer brake controller. I see the spot in the dash is there to accept one. I pull trailers all the time and the need for a brake controller is great. I had to add a receiver hitch already, I can't believe there are pickups sold in todays world that do not come standard with them.
Anyhow was just wondering if anyone has added the factory controller and what is needed to do it. I was going to stop by the dealer and price one out and pick their brain as well about the issue.
05 Cummins 4x4 QC SB 112k,10 Hemi 4x4 QC SB 60k
sold 02 http://www.youtube.com/watch?v=i3TkO071kTk
Old 02-16-2012, 02:16 PM
brc3858's Avatar
brc3858 brc3858 is offline
Color: Red/Silver two tone
Rep:33
brc3858 is on a distinguished road
Yeah as long as your truck is a 2010 or newer the wiring should all be there. For some reason the 2009 trucks do not come with the wiring. I installed the factory controller shortly after I bought my truck and it was very easy and works great. Talk to the dealer they should be able to order the kit from the factory they will need the VIN number for your truck to match the dash color because it will come color matched. If I remember correctly the kit was around the $175 mark but don't quote me on that. The only thing I am not sure on is the trucks that come from the factory with the controller have an extra readout on the dash for the brake controller. I'm not sure if that is something the dealer can re-flash your computer to add or not, I never bothered on mine because I didn't really need it. The controller has all the info I need on it so I figured I can just look down if I need...lol! Hope this helps!!
Old 02-16-2012, 02:36 PM
Toon tugr's Avatar
Thanks, I am headed to town today and will stop and check on the dash indicator as well. Mine is an early 2010 MFG date of 10-09, hopefully it has the wiring.
Old 02-16-2012, 05:27 PM
GearHd6's Avatar
GearHd6 GearHd6 is offline
Vehicle: 2010 Ram 1500 CC
Color: Mineral Gray
GearHd6 is on a distinguished road
Post back your results Toon tugr. I have pretty much the same truck and would someday like to add that option to my truck.
Old 02-16-2012, 07:30 PM
Toon tugr's Avatar
Just got back from dealer and visited with a friend who is a technician there, he said they need to contact chrysler and add it to the factory spec sheet and then get an ok from them to enable the factory ecm option to recognize the brake controller in the system. I ordered the factory controller and it comes as a kit with 2 different color bezels to match the dash. he said I can install it but do not plug it in until they enable the system.
Kit was $230 + what ever the cost will be to enable probably 50-60 bucks.
Old 02-16-2012, 08:20 PM
Jsty093083 Jsty093083 is offline
Vehicle: 2010 Dodge Ram 1500 Big Horn
Trim Level: SLT Big Horn
Rep:17
Jsty093083 is on a distinguished road
same here only mine worked right out of the box. installed it myself and such. Just called the dealer and they said they can flash it to show up in the ECU if i wanted. Probably have that done when it goes in for some recall work.
RC leveling kit. American eagle 20x10 -21 offset wheels. EGR flat black pocket style flares. War paint hood decal. Magnaflow cat back system. AFE stage 2 intake. Diablosport trinity w/ Hemifever tune. Sony XAV-701hd w/ 10" kicker. Air lift 1000 rear leveling kit.
Old 02-18-2012, 05:20 PM
Toon tugr's Avatar
Well brake module kit came, very simple 10 minute install but there are supposed to be 2 harness connectors under the dash and be danged if I can find the second one. there is a large 4 blade and a small 4 blade square connector and I can not find the smaller of the 2 under the dash anywhere.
Guess the dealer will have to find it when they update the ecm and plug it in next friday when I get my right front axle shaft seal replaced.
Old 02-24-2012, 02:15 PM
Toon tugr's Avatar
Would be nice if the mods would let a person know when they move a thread to a different section.
I just got back from the dealer for some warranty work and to have them program the pcm to recognize the brake controller and found out my 2010 is an early enough build that it didn't come with the new wiring harness and thus will not accept the factory brake controller. My 2010 was a build date of 10-09 so anyone out there take note of this. there are supposed to be 2 connectors for the factory controller mine only has 1. so now to look for an aftermarket one.
Dealer even looked up the vin before ordering it to make sure it would work but they missed the mark on this one.
Old 02-26-2012, 01:36 PM
Toon tugr's Avatar
Well after looking around I found another way to install an aftermarket controller in the little cubby hole slot in the dash where the factory one would have gone. I found a "Curt" brake controller that is small enough to fit inside the pocket and keep the underside of the dash clean and have the controller in its designated spot. I will post pics as I do it. I am going to drill an hole in the back side of the pocket for the controller harness to fit through and will velcro tape it in place. It will be a very simple and clean install.
Old 02-26-2012, 02:12 PM
snkmug snkmug is offline
Vehicle: 2012 Ram Express
Rep:13
snkmug is on a distinguished road
you can buy the second harness on ebay and make the factory one you bought work. Its just a power harness, and it only needs to be programmed by the dealer it you want it to display on the evic. If you dont program it will still work like an aftermarket unit will....
