Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-04-2014, 06:30 PM
jeffatjacks jeffatjacks is offline
Vehicle: 2003 ram 3500 srw
jeffatjacks is on a distinguished road
Default stalls cold
hi 1 st time post here. my 03 3500 5.9 diesel ram will not stay running when its cold out. i replaced the injectors 6 months ago due to the usual starting problems. not plugged in it starts right up @ 20 degrees, it will go into fast idle mode if i let it warm up, 10 or 20 miles up the road it will stall at a light. it will re-start however and if i slip into neutral and keep the rpms up to 1500 or so i can keep it running. scanned system ...no codes or pending codes, filters all good. after an hour or so of running it will be ok. only is a cold weather issue as i have been in fla. for the last few weeks and it was fine. this happened before back in nov. during a cold spell. also i added anti gel conditioner to fuel supply with no change. any body got any ideas? thanks in advance...
