Old 01-06-2014, 08:26 AM
patricklee85's Avatar
patricklee85 patricklee85 is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT Big Horn
Color: Blue
patricklee85 is on a distinguished road
Default No Power This Morning - Super Cold Outside
Its about -25 degrees out with God knows what kind of windchill this morning. My factory remote start didn't want to work so I went out to start with the key fob. It started to crank, slowly, and then the alarm started going off. I got the alarm to quit and attempted to start it again. After some extended cranking, it finally fired up. Let it sit and run while I got ready for work.
Started heading to work and notice that I can only go about 15-20mph and that I have check engine light on. Its not running rough, just wont go.
FYI I have a DS inTune tune loaded.
Could something have happened with the computer?
Could it be something with the security system limiting power being as the alarm went off?
Any guidance will be appreciated.
If it works, it works.
Old 01-06-2014, 08:39 AM
C17LoadMaster C17LoadMaster is offline
Vehicle: 2013 Ram 1500 CC
Rep:48
C17LoadMaster is on a distinguished road
Not sure about the alarm and tuner etc... But I would recommend that you have your truck plugged in when its that cold. When its -40C here there is a twenty to thirty degree temp difference in the oil and coolent when its pluged in and not. This should help with the sluggish cranking. If you are already plugging it in then disregard this post completly.
Keep Calm & Chive On !
Old 01-06-2014, 08:50 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Low battery voltage from cold temps and extended crank time ? Is the charging system working ? What happens if you shut the truck off and restart it ? If everything is ok after a warm restart I would check the battery and see if it may be failing. Love these Minnesota winters !
Old 01-06-2014, 09:17 AM
Color: Blue
I have not been plugging it in, hasn't seemed needed yet.
My charging system seems to be working fine, at least according to my dash guages. I did shut it off when I got to work and restart it and sitting in park I could rev my rpms like normal. But I will see at lunch how it's running. If its still having issues, i'll pull it into the shop and check a few things.
Keep the ideas coming guys!
Old 01-06-2014, 09:20 AM
Hemi All Day's Avatar
Hemi All Day Hemi All Day is offline
Vehicle: 2014 Ram Sport
Hemi All Day is on a distinguished road
How is it running now?
Billet Catch Can, BakFlip G2, 17" XD Rockstar 2, 295/70R17 Nitto Trail Grapplers, Recon Smoked 3rd Brake Light, Retro Shop Low Beam 6000k HID kit, Retro Shop Fog Light 6000k HID Kit, Front tint: 15%, Rear tint: Double Limo.
Old 01-06-2014, 09:27 AM
Color: Blue
Haven't ran it since lunch, been in my office. But it was running smooth, no noises or anything like that. Just no power and wouldn't get past 15-20mph. I'm going to go put my code scanner on here shortly if I get a chance.
Old 01-06-2014, 09:48 AM
Vehicle: 2012 Ram
Rep:163
Sounds like a "limp mode" to protect the truck ?
Old 01-06-2014, 09:50 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Being a 2009, original battery I take it? I think besides the plugging in the engine heater is concerned, it would most certainly help. But I think your battery is on its way out. Your Cold Cranking Amps in your present battery is probably about done son.
Old 01-06-2014, 10:05 AM
Color: Blue
Well, that would explain the hard start in the cold. But with the alternator properly charging the system, how is that going to effect the performance while running? CCA should have no bearing on performance past starting the vehicle. At least in my mind, correct me if I'm wrong.
Old 01-06-2014, 12:31 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
You may have a bad cell in the battery and not getting the full 12 volts and the alternator is trying to charge the battery and is having problems. Check to make sure you have 12 volts with the engine not running and 14 volts running.
If you have less than 11 volts you have a bad cell and will need to replace the battery.
JMO and it could just be the cold temperature.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
