Old 01-06-2014, 03:56 PM
Broda2675 Broda2675 is offline
Vehicle: 2012 Dodge Ram 1500
Broda2675 is on a distinguished road
Default Trailer Brake Controlle
Hi All,
I am a new member so bare with me. Sure could use HELP !
I bought a new Ram 1500 Big Horn November 2012 from a dealer up North. My truck did not come with the trailer brake module installed; the dealer told me - no problem i could add it anytime i wanted so i bought the truck. I moved down South and this December 2013 i went to the local dealer. The parts department sold me a 82212548 Brake Controller. After the part came in i scheduled to have it installed from the service folks. Service told me it would take about 1 and 1/2 hours to install, so i waited. Two hours later, service told me they could not install the module in my truck. Seems the issue is that my year truck came with two different wiring harnesses, one with two connectors and my truck with one connector - the brake module requires two connectors.
Now that i am buying a travel trailer, i find out that my truck does not have a factory option for trailer brakes. Had i known this at the time of purchase, i would have chosen a different vehicle. Anyway, aftermarket options (if spliced in) void the warranty and the don't interface with the EVIC (no dashboard display). They also install in a manor that seems to interfere with your knees, and they are hard to see.
Has anyone found an older OEM part that installs into the slot on the left?
Thx Roland
Old 01-06-2014, 06:51 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Red/Grey
Rep:69
slimpartywagon will become famous soon enough
so why not get an aftermarket Trailer Brake controller and harness?
Old 01-06-2014, 07:05 PM
Rep:2597
The OEM Brake Controller can be installed in a Ram with only the single connector, the kit was suppose to be available sometime in 2011 from the dealers
There is thread about how to do it here on this site, it is a long read because of all the posts concerning it
http://www.ramforumz.com/showthread....roller+harness
Also you can go to the Etrailer website & get a nice after market brake controller, but it can be a knee knocker, if you have long legs
Old 01-06-2014, 07:11 PM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
I bought a tekonsha p3 from etrailer for mine. The wiring harness is direct plug and play. No splicing at all.. Check out the 4th generation towing section here on the forum there's a few threads about brake controllers you can look at
Old 01-07-2014, 02:29 AM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:179
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
I have a Tekonsha P2 on mine. Harness plugged right in under the dash. Works great, never had any problems
