No floor heat - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 01-08-2014, 11:01 AM
Jmbeam3131 Jmbeam3131 is offline
Vehicle: 2006 Dodge RAM 1500
Color: Two-tone red and silver
Jmbeam3131 is on a distinguished road
Default No floor heat
My 06' RAM doesn't blow heat onto the floor. When the heat is turned to floor it only barely blows hot air out the floor vents with the majority coming going to defrost. What is the problem and what do I have to do to fix it?
Old 01-13-2014, 04:29 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
There's a door inside your HVAC system that directs the blown air to the desired position. Sounds like that door has become stuck. You'll need to get up under the dash and remove the fan, then possibly replace the door or the motor. Could be that the controller is acting up as well.
Old 01-22-2014, 04:57 AM
ShakieHead ShakieHead is offline
Vehicle: 2003 Dodge Ram 1500
Rep:18
ShakieHead is on a distinguished road
Its the mode 2 door. It broke and when they break, they fall and block the vents in the floor. It is the biggest PITA to replace and it will cost some money to have someone to do it. If you want to verify it, it's pretty easy to take dash out. Comes out and 5 pieces, would recommend a cordless drill. The mode 2 door is located behind the metal plate in the center of console floor above trans tunnel. If you can get the motor off, there is a gear and spin it. You can tell if the door is there or if the stops are in place. A company called Heater Treater makes aftermarket doors an also have videos. I would check them out, and watch there videos to help get a idea of what the location, and work involed in doing the replacement.
Old 01-23-2014, 12:10 AM
Rep:2968
Most excellent post, ShakieHead! Thanks, and reps, for the input.
Old 01-24-2014, 10:46 PM
Hallock21 Hallock21 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:30
Hallock21 is on a distinguished road
yep...same problem im having, it is mode 2 door and is also a pain in the arse to fix.....like Shakie said up there
