Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 01-10-2014, 11:12 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
Ok, at the risk of starting another flame war...
Why syn vs conventional? If I take my truck in to the dealer for an oil change, can I request syn? And what is the typical cost difference?
S S H A D O W
Old 01-10-2014, 11:15 PM
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:54
The Crow 1994 will become famous soon enough
Pennzoil Platinum for me, too, and a Fram Ultra Synthetic oil filter. I'll be getting my truck's first oil change this week. It'll be right around 6000 miles on the odometer.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Airlift 1000 Air Bags, Airlift Wireless One Remote System with Onboard Compressor, & Weathertech Digital Fit Floor Liners
Old 01-11-2014, 08:01 PM
1979WagoneerLTD's Avatar
1979WagoneerLTD 1979WagoneerLTD is offline
Color: Silver/grey
Rep:13
1979WagoneerLTD is on a distinguished road
Another way to approach the question is "what isn't the difference?" As far as the manufacturer is concerned, if it isn't specified, then you'll see no advantage in using synthetic. If it makes the user "feel" better, then by all means do it.
Yes, the dealer will gladly upsell anything they have on the menu.
2.5 to 4x greater cost for the upsell of your choice.
Bottom line, follow the manufacturer's suggested weight and API rating for the application. Same stands for the filter; pick your color.
Old 01-11-2014, 08:31 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
There is one clear advantage I believe--longer intervals between oil changes. You can go longer with synth than without. I've always wondered if the extra cost of synth makes that a wash though.
I asked a dealer mechanic today and he said no it's OK to use synth right off the bat. Says if the manual doesn't say one way or another it's OK to use either in all newer engines. Some high performance rigs mandate that you use synth I guess. Said it's still a bit of a concern to run synth in old vehicles though.
Old 01-11-2014, 10:32 PM
Rep:156
Conventional oil it is then... If there is no benefit, then I need to go the cheapest route.
S S H A D O W
Old 01-11-2014, 10:51 PM
BigRedRam1500's Avatar
BigRedRam1500 BigRedRam1500 is offline
Trim Level: Laramie Longhorn 4x4
Color: Deep Cherry Red & Gold
Rep:58
BigRedRam1500 will become famous soon enough
From what I have read about synth. oils, another benefit is the bonding/coating of the internals at a moleculer level. When starting it will provide better protection as this is the most critical time as the motor warms up and the oil circulates.
Old 01-14-2014, 04:13 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
The dealership here in Salt Lake City charges $34.99 for Pennzoil 5w20 and a mopar filter. If I want synthetic Pennzoil 5w20 and a filter its $84.99
I can do it myself for less than the dealer charges for synthetic.
I just did my first oil change and I bought 7 qts of Valvoline 5w20 and a Fram filter and it cost me $44.xx and then I spent $6.50 to rent a lift on base and did it myself. I paid more than the dealer would have charged for a standard oil change but I don't want Pennzoil in my truck. I'll change it again in 5k and switch to synthetic Mobil 1 or maybe Castrol Syntec. I have always had good luck with Castrol oil and ran many engines up over 250k using it w/ no lifter tick or anything. I've seen Pennzoil foam up and turn milky white and I don't want that crap in my Hemi.
Walmart Super Tech oil or whatever the local parts store has on sale for 5 qts of oil and filter combo. Just remember to grab 2 additional qts.
I did notice the aftermarket filters are larger diameter than the OEM Mopar filter, but the gasket sealing surface is the same size. I didn't like the face that it dripped oil all over my steering rack and pinion though. I used some old rags to soak that up and wipe it down but I might look into a filter relocation kit if anyone makes one that will fit this truck.
Then before you start the truck, turn the key til the dash and radio powers up, then push the gas pedal to the floor 3 times. This will reset the oil life monitor and put it back to 100% oil life.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 01-14-2014, 04:37 PM
finn5033's Avatar
finn5033 finn5033 is offline
Vehicle: 2014 Ram 1500 cc 4x4
Color: Granite
Rep:32
finn5033 is on a distinguished road
I use synthetic because using the vehicle oil life computer I get around 8,000 miles between changes with synthetic and 4-5k with regular. Being it does come out pretty close to a wash I choose to use synthetic and not have to change it as often.
Old 01-14-2014, 08:24 PM
pitch1 pitch1 is offline
pitch1 is on a distinguished road
My oil life monitor does not seem to do any thing. It reduces oil life 10 % just about every thousand miles. Never varies winter, summer, towing ,or empty.
Old 01-14-2014, 11:19 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Oil life monitor has no idea what oil is in the engine. It uses algorithm to determine oil life.
"I don't care to hear what your ideas are, mine are better"
