Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 01-10-2014, 10:27 PM
brc51m brc51m is offline
Vehicle: 2011 Dodge Ram 1500 Laramie
brc51m is on a distinguished road
Default Front brake pad change question
I changed my front pads with the cheap duralast pads from auto zone. This was my first time changing brake pads and all went smooth. When I drove around I noticed that I have a really loud squeal when I push on the brakes. Just wondering if I did something wrong during the install. The truck stops fine it just really noisy. Any suggestions?????
Old 01-10-2014, 11:55 PM
treetopdodge treetopdodge is offline
Vehicle: 1997 Dodge Ram
Trim Level: Magnum SLT Laramie
treetopdodge is on a distinguished road
Did you clean them with brake cleaner before putting them on and make sure there wasn't any grease or any other contaminate on the rotors or pads?
Old 01-11-2014, 12:41 AM
Nope.......guess I'll be trying that tomorrow. Thanks
Old 01-11-2014, 12:46 PM
seppie10 seppie10 is offline
Vehicle: 2010 Dodge Ram 1500 Trx4
Trim Level: TRX4
Color: INFERNO RED/GRAY
Rep:19
seppie10 is on a distinguished road
Just lube up your caliper pins with sil lube and not anti seize. If your doing a brake job are u putting on new rotors? If i were u I would but that's me. I don't like brake vibration. That's when you get out the brake clean and clean the oil off of the rotors. Good luck and make sure you brake in your pads.
Old 01-11-2014, 03:42 PM
Chunkem's Avatar
Chunkem Chunkem is online now
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Good luck my friend.....Please let us know how things work out.....
Old 01-11-2014, 03:48 PM
Rep:2616
I recently replaced my pads, had to get the rotors turned, they had a ridge on them
