Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 3.7L (226 cu in) PowerTech V6 Specific Topics
Old 01-11-2014, 06:24 PM
npenn2010 npenn2010 is offline
Vehicle: 2009 Dodge Ram 1500 3.7L v6
npenn2010 is on a distinguished road
Default 09 ram1500 3.7L v6 fuel economy increase
hi what can i do to increase the fuel economy on my 09 ram 1500 quad cab with a 3.7L v6. I make 16mpg to 16.5 hwy and city driving. I really need to increase the mpg. hurting the wallet too much. any help is greatly appreciated
Old 01-12-2014, 08:14 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
Air in the tires.
"I don't care to hear what your ideas are, mine are better"
Old 01-29-2014, 12:54 PM
Originally Posted by Swaggerville Ram View Post
Air in the tires.
ha ha...got air in the tires.... tires are rated for 44 psi max. i put anywhere between 40-44 psi in them.
Old 01-30-2014, 12:09 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
other than driving habits, there is nothing you can do or change to get more mpg. good engine, from the days of cheap gas, but they are thirsty.
Old 09-05-2014, 01:49 AM
davepamh's Avatar
davepamh davepamh is offline
Vehicle: Red 2010 Ram reg cab
Trim Level: ST w/3.7L 210hp
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
davepamh is on a distinguished road
Default Some help for you
Hi the two most common things you can do to your truck are:
CAI (Cold Air Intake)
Freer flowing exhaust (a better muffler and exhaust pipe or pipes) plus they sound good too.
After these the mods and gains from other mods for our little 3.7 are both expensive and show very little gains.
The early bird gets the worm, but its the second mouse that gets the cheese!
Old 09-05-2014, 09:40 AM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:15
Hemi HFE is on a distinguished road
also, more ideas:
- swap gears / final drive ratio to a lower numeric set
- run 'fuel max' or other 'ECO' tires
- run narrower tires
- lower truck
- tonneau cover
- remove unnecessary weight (junk in trunk)
- drive slower, drive smoothly, coast into stops, etc. (braking = lost energy = lower FE)
- use A/C (and defrost) as little as possible
- use cruise control as much as possible (except in hilly terrain where it will downshift too much)
- high mileage truck = fresh (front) oxygen sensor(s?); as they age, they read lower = more fuel
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
3.7, 3.7l, 3.7l v6
