Old 01-11-2014, 11:10 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Default replacing the stock alpine sub only
did anyone ever tryed to replace the stock sub(not the box, just the sub itself) by a aftermarket sub without replacing the stock amp,..
did it work and did it improve the bass?
2nd question,.. i dont have my truck yet so i cant mesure,.. but is there any chance i could enlarge the hole and fit a 10inch sub in the original alpine box?
i'm not sure if it would fit but heres one that might: Rockford Fosgate P1S2-8 Punch P1 SVC 2-Ohm 8-Inch 200 Watt RMS 400 Watt Peak Subwoofer
http://www.amazon.com/Rockford-Fosga...2ohm+subwoofer
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 01-11-2014, 11:23 PM
crusher's Avatar
Rep:363
since the stock amp is probably not strong, i woulnd chose a high wattage sub,. probably around 200w ,.. i think it could work and improve the bass
Old 01-13-2014, 02:00 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2067
I haven't heard of anyone do what you're subscribing but a few guys have replaced the sub and added an aftermarket amp to run it. gcscott was one of them... do a quick search for him and you'll find the thread.
Old 01-14-2014, 08:02 AM
BBRam BBRam is offline
Vehicle: 2011 Dodge Ram
Trim Level: QC Laramie
BBRam is on a distinguished road
http://www.ramforumz.com/showthread.php?t=151034
Debadged, Rhino Liner, stubby ant, Gorilla BC lugz, caf
Old 01-15-2014, 09:01 AM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
Enclosures make or break even the very best subwoofers...with that being said, you would be better off replacing the factory enclosure with something better built and re-using the factory subwoofer (though it's not a popular move)
The factory enclosure is pathetic.
I'd plan on replacing both, and while you're at it, buy an aftermarket amp to power the sub too. It may be an "Alpine" system, but there is much to be desired
Old 01-15-2014, 01:41 PM
crusher's Avatar
Rep:363
Originally Posted by BBRam View Post
yes thanks i have seen his thread but i was more thinking of doing a quick swap and not everything just like others have done to the front speakers,. which they had great result
