Engine swap from a 2006 ram 1500 to a 2006 ram 2500! Can it be done? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 01-12-2014, 08:21 PM
Ramitdamnit's Avatar
Ramitdamnit Ramitdamnit is offline
Vehicle: 2006 ram 2500
Ramitdamnit is on a distinguished road
Default Engine swap from a 2006 ram 1500 to a 2006 ram 2500! Can it be done?
Junk yard that I'm trying to get a used engine from says it won't work! What's the difference in the engines? Mounts?
Old 01-12-2014, 09:03 PM
Rep:2929
the blocks are identical for cars, Jeep, Rams from the 1500 up to the 5500 models for the same years.
2006 was the first year for the Ram to use the MDS in the 1500s, the MDS was not put in the 2500 - 5500 models, at least before the 2013 or newer Rams
the 1500 engine has MDS, therefore it uses a different camshaft & uses different sensors & a different computer or at least the programming
if you put a 2500 engine in a 1500, the computer firmware would be searching for input from the sensors & may be throwing a code
It could possibly be fooled by switching some sensors too
I don't believe that the engine not having the MDS equipment would throw a code
somewhere i read that some people have blocked off the lines that control the MDS, like the Air Line or using a tuner to stop it from working
You would need to research that some more, maybe on a Jeep site
https://www.google.com/#q=eliminatin...Jeep+hemi+mds+
Good Luck with your swap & keep others informed
Old 01-13-2014, 01:05 AM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
To convert the 2500 non MDS engine to work in your 1500 with MDS, all you need are the cam, MDS lifters and the valley solenoids that control it. Reuse your original sensors and you should be golden.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
