Old 01-13-2014, 03:55 AM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Default Do these factor into retro grill light mounting?
A couple things cross my mind when I look at the various installs of aftermarket lighting behind the grills. Hella, for example.
  • They appear to block approx. 20% of the rad. Will this have consequences on cooling?
  • Do these lights generate enough heat to ever damage the grill?
Thanks
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-13-2014, 10:25 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
I have a set of KC Dayliters behind my grille now and i live about 2.5 hours from my parents house, i have ran them on for 90-95% of the entire trip and they have never made the plastic more than warm to the touch. As for cooling, My truck does have the HD cooling package on it with the over sized radiator and trans cooler but i have yet to even see a difference of a degree of what it runs at while driving down the road or idling in downtown traffic
Old 01-13-2014, 02:13 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Just a note, if you have the grille shutters, you will have to mount the lights in front of the grille shutters. The cross member is behind the shutters. So you will have to make a mounting bracket for the lights.
JMO
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 01-13-2014, 04:01 PM
macc08's Avatar
macc08 macc08 is offline
Rep:722
i dont think them blocking the rad is going to have any significant affect on cooling. and as kamanhart said, The grille has never gotten very warm from them.
Do i see a mod in the future??!
Old 01-13-2014, 07:20 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
Thanks guys. It's reassuring to get some real world input. Behind the grill is definitely an option when I mount my LED lighting. If so I'll have to fab up a bracket as mentioned.
My first choice for the LED bar would be in the lower valance insert area below the plate area. Still have to measure that space up to see how I can mount the bar up.
Old 01-13-2014, 08:33 PM
RandyW's Avatar
RandyW RandyW is offline
Vehicle: 2014 Ram 1500
Rep:156
RandyW has a spectacular aura aboutRandyW has a spectacular aura about
One of the benefits of LEDs is that they don't really put off any significant amount of heat.
2014 Ram 1500 4x4 Crew Cab Big Horn (3.21 gears) - Black Ext. Black/Grey Int. Mods include: Weathertech Digital Floormats, Limo Tint + Windshield, 2.5" HBS Leveling Kit, Blacked out badges, LED bulbs Interior/Exterior, 13" Stubby AntennaX, In-Cab Air Filter Mod, 18" Ultra Baron Wheels & 275/70R18 Nitto Trail Grapplers.
Old 01-13-2014, 10:13 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
Agreed. My initial question was looking at the hellas I see many installing. I was thinking they might throw off too much heat but by the sounds of it they do not which is great.
One day I'll look for the exact light bar specs off of the Baja Designs site and then go out and see if that lower valance insert (removed) can accommodate the bar.
I still think it's cool that we can install Hella's behind the grill. Pretty stealthy.
Old 01-14-2014, 06:34 AM
macc08's Avatar
Rep:722
It really is a great look, however, they put out the normal yellowish colour light, right? so if you had HID's in your lows/fogs, the colours may not coordinate very well... but otherwise, I love them. I recently re-aimed them as I had them a tad too low. I now have them lined up with my lows, but just underneath.
also, I was thinking about the same thing for an LED bar! That plastic valence under the plate is just screaming for a light to be put there, lol
