Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 01-13-2014, 10:58 AM
vortex911 vortex911 is offline
Vehicle: 2013 Ram 2500 Power Wagon
Rep:24
vortex911 is on a distinguished road
Default Leveling and 20's with 35's
Ok after tons of research on different fourms I have decided to level my 2013 PW. I am going to install leveling coil spacers. Many people are running them without issue and this seems to be the most economical way to level the front end. My goal is to get rid of the dredded rake and have extra room for 35's. I do not plan on doing any hard core off roading so I think this should suffice. My question is what rim offset/backspacing should I use to run 35's and keep the wheels tucked in the wheel well? Any help would be greatly appreciated.
Thx, Dave
Old 01-13-2014, 09:10 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
With the power wagon, you should have no problem fitting 35's!
Old 01-14-2014, 09:34 AM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Power Wagon
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
I think the key is to find a wheel the same width as stock. I believe the stockers are 11.5" wide. From what most people look at with 35s they are 12.5" wide. That inch makes a big difference. If you don't get a wheel with a different offset, you can get new control arms from Thruen of Carli.
Old 01-14-2014, 05:17 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
The stock wheel is 9" wide. If I am not mistake the backspace is about 5.25" so you would be looking for something in the 4" backspace range to avoid rubbing.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 01-15-2014, 12:20 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Rep:26
06PowerWagon is on a distinguished road
http://www.tirerack.com/tires/tires....omCompare1=yes
Look at the specs... they are 11.5 in width and tread width 9.2
Sledlvr .... truck http://www.ramforumz.com/showthread.php?t=137878&page=4
Smile even if its a little creepy
Old 01-15-2014, 04:57 PM
Rep:256
The tire is 11.5" wide, He specifically asked about the wheel.
Old 01-16-2014, 04:59 PM
Eagledriver Eagledriver is offline
Vehicle: Dodge ram 4x4
Trim Level: 2500
Color: WH/BLK
Eagledriver is on a distinguished road
im running 35x12x50x20s nitto mts my wheel have +18mm back spacing no rubbing at all.
Old 01-19-2014, 09:24 AM
Rep:24
Eagle driver do you have any photos of your set up? Are you running Nitto Mud Terains or Trail Grappler Mt's? What rims are you running? Im looking at Fuel Mavericks 20x9 with +20 offset and Nitto Trail Grapplers.
Old 01-19-2014, 09:27 AM
Rep:24
[QUOTE=vortex911;1300567]Eagle driver do you have any photos of your set up? Are you running Nitto Mud Terains or Trail Grappler Mt's? What rims are you running? Im looking at Fuel Mavericks 20x9 with +20 offset and Nitto Trail Grapplers.[/QUOTE
Do you have a leveling kit installed
Old 01-19-2014, 06:30 PM
BgDannyP BgDannyP is offline
Vehicle: 2013 Powerwagon
BgDannyP is on a distinguished road
http://www.kmcwheels.com/wheels/XD79...Ram&model=2500
35" BFG mud terrains on the above rims. Kore suspension, which would be close to your leveled powerwagon. 5.7" backspacing with 18mm offset, no rubing even with the swaybar disconnected.
