Old 01-14-2014, 09:20 AM
pitch1 pitch1 is offline
pitch1 is on a distinguished road
Default Heavy duty transmission cooling
What does Ram mean by this? I tow a 6000# travel trailer, salesman said I did not need an external cooler. I have seen tranny temps just under 200. What is too high? Do I need an additional cooler?
2013 sport QC
5.7, 6 speed,3.55 17" tires
Old 01-14-2014, 09:25 AM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
200 is very safe yet. normal is from 150-220 ..you start bumping 230-240 your looking for a added cooler.
I always go by. your trans temp should be close to your engine temp.. truck runs 200 trans runs 200 ... if your truck is running 200 and the trans is 240 ...you got problems....
Old 01-14-2014, 07:52 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
adding a cooler wouldn't hurt.
Old 01-14-2014, 10:12 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Your truck has a trans cooler,it's integral with the ac condensor(it's the top ~10 rows). bartlett's comments are spot on. They define "normal" or "average" as 180 deg F.
Sean
Old 01-15-2014, 12:21 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
200 degrees now. Towing 6K with the AC on, in the depths of summer, may change that.
Old 01-15-2014, 05:31 AM
Color: gray
Rep:323
Trans fluid can handle 270 degrees. your truck can pull 6,000lbs all day all night all summer ac on up hill in a head wind with one trailer brake sticking and a low tire. drive it
Old 01-15-2014, 02:05 PM
chrisb38002's Avatar
chrisb38002 chrisb38002 is offline
Vehicle: 2013 Dodge Ram
Trim Level: R/T
Rep:86
chrisb38002 will become famous soon enough
I'm wondering why these trans temps are that high. I checked mine yesterday and my trans temp was running between 120 and 130. I have never seen anything above 160 on the hottest day.
Here is what I had going about 65mph after about 30 minutes of stop & go due to construction. My trans temp was 122.
Sorry it's kind of blurry, hard to take the picture and drive at the same time.
2013 White Ram R/T
Mods: BT Catch Can (red), Mufflex DOD24, S&B CAI, BakFlip VP Tonneau, McGaughy's 2/4 Deluxe, Spohn Adjustable Panhard, AirLift 1000, Hellwig Rear SB.
Old 01-15-2014, 02:50 PM
Color: gray
Rep:323
are you pulling a 6,000lb trailer ? 120F for a trans is very cool for a 70 degree day. it takes a good 1hr of easy no trailer driving to get upto temp .
Old 01-15-2014, 03:22 PM
Rep:2657
The websites that i get the best information from, all read that the transmission temperature should be the same as the engine oil temperature
A segment exclusive on the 2013 Ram 1500 is a new thermal management system, designed to quickly raise the transmission fluid temperatures to cut parasitic losses and wear, improving fuel efficiency by 1.7%. It is enabled by an electronic thermostat which constantly monitors antifreeze temperature; once it’s hot enough, warm engine coolant is circulated through a thermal exchange unit which heats up the transmission fluid. In most vehicles, the transmission heats up independently of the engine. (The system also works for engine oil.)
Chrysler’s Dave Sowers said:
We get benefit from bringing both of them [oil and transmission fluid] up to operating temperature faster. The primary benefit comes in the transmission. In colder climates, you could drive a vehicle for hours in the winter and the transmission might never reach that 190 (F) for the most efficient operation. So what we do is use some of that hot engine coolant through the heat exchanger to bring it up to 190 as quickly as possible, and that gives us efficient operation very quickly.
Original is at 2013-2014 Dodge Ram 1500 engine, transmission, and axles (powertrain) http://www.allpar.com/model/ram/dodg...#ixzz2qV5TRk86
Follow us: @allparcom on Twitter | allparcom on Facebook
Old 01-15-2014, 05:01 PM
dodge.ram dodge.ram is offline
Vehicle: 2006 Dodge Ram
dodge.ram is on a distinguished road
How are you guys monitoring your temps? My in truck gauge has no temp markings on it
