trying to figure this one out - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 01-15-2014, 04:54 PM
Just Eric Just Eric is offline
Vehicle: 2006 Ram 1500 4x4 Sport
Just Eric is on a distinguished road
Default trying to figure this one out
I have an 06 ram with a 5.7. I noticed, during the cold snap last week that it was leaking a pretty good amount of coolant. I thought I isolated the problem to either the thermostat housing or upper radiator hose. Replaced the hose and put a gasket in the housing. The first day that I was going to fix it, I drove it to a friends house (he has a heated shop) and we went to working on his car while my truck cooled down...well it didn't leak. couldnt figure it out...so we decided to wait to see if it would resurface or get worse.
Another cold day (-10 windchill) and it was leaking again. (this is when we replaced the hose and gasket). Now to make a long story longer, it is still leaking from somewhere but I can't find it. The drip is coming off of the lower power steering mounting bolt. with a little wet noticable at the upper mounting bolt. there is NO wet anywhere above that. I don't know why the drip would be there as the only coolant above that is the upper hose and thermostat housing. it is off to the side of the water pump so if it were coming from that, it would be wet beneath the pump verses 8 or so inches to the right. I have mostly noticed the drip once it has been sitting for a little bit (i really only drive the truck on weekends)
Any ideas?
Old 01-15-2014, 04:59 PM
JasonGriff's Avatar
JasonGriff JasonGriff is offline
Vehicle: 2009 Dodge Ram TRX4
Trim Level: TRX4
Color: Blue and gray
JasonGriff is on a distinguished road
Is it only after it has been very cold?
2009 TRX4 ^ 4" BDS lift^ 35x12.50r20 kumho venture mt ^ 20x10 ^ drop in K&N ^ 3.92's^ 5% TInt
Old 01-15-2014, 05:07 PM
it was in the beginning. it is not leaking enough to drip onto the floor but is constantly wet at that bolt now.
Old 01-15-2014, 05:15 PM
JasonGriff's Avatar
Trim Level: TRX4
We have some equipment out here (in the gulf) that leaks really bad only when it is setting up and it is cold. They had to go with different gasket materials on cooling pipe joints that would not shrink in the cold, and we never get -10 down here. It may be a gasket material problem or a small crack that gets larger when the metal is cold. Just some ideas.
Old 01-15-2014, 05:29 PM
you are the second person to tell me something like that....appreciate it!
Old 01-15-2014, 06:01 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Just think back to the challenger disaster, wasn't that a bad seal when cold ??
sales@revelperformance.com
Old 01-15-2014, 06:37 PM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
I would try tightening any bolts first to see if any where a little loose before replacing anything.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
