Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 01-16-2014, 10:40 AM
SIC09 SIC09 is offline
Vehicle: 2009 DODGE RAM Hemi
Rep:36
SIC09 is on a distinguished road
Default Should my MPG be better then this?
Hey guys, so im looking through these recent threads on here and notice im getting pretty bad MPG, lol.
i have an 09 1500 5.7 4x4 with 65,xxx miles
i live in NM so cold wise its not that bad.
All i have done to the truck so far is,
S&B Cold air intake
Flowmaster Exhaust
Tires are 285 Hakook all terrain
17" XD spy
im getting 13.9mpg i did change out all 16 plugs yesterday. so so far it did go up to 14.2 does that seem normal for the mpg? also, my driving is all highway driving 50 miles a day while using mid grade.
thanks for any help
Signature coming soon...
Old 01-16-2014, 12:09 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
S&B Cold air intake
Flowmaster Exhaust
17" XD spy
thanks for any help
First off, you bought a truck with a HEMI, so gas mileage shouldn't be your first concern. With that said, your mileage is right in the ball park. Plus, you're running winter grade fuel which isn't known for getting the best bang for your buck. Changing the plugs is a good start. Run some Seafoam through your gas tank to clean up the lines and injectors. Also, if you're not running a synthetic oil in your HEMI, I would suggest doing so. And, a lot of your mileage depends on your driving style. If you're like me, and most others here on the Z, you like to punch it to let other drivers around you know that you've got a Dodge, or just because it's fun. Getting in the skinny pedal easy and letting off and coasting for a while before coming to a stop will go a long way with MPG. Try driving 5 miles under the speed limit as well. Those are the tricks I use, and my mileage went up by 4 to 5 mpg by just watching my driving habits.
Old 01-17-2014, 08:03 AM
Hemi HFE Hemi HFE is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: SLT / HFE
Color: White w/ brown&beige interior
Rep:15
Hemi HFE is on a distinguished road
the three main factors affecting the fuel economy of a particular truck are (in order of impact):
1. driving loop & "driving style"
2. final drive ratio
3. tire type/size and wheel+tire weight
1. you say "my driving is all highway" but fail to list average speed...
big difference if yur rockin' 78mph vs 68 or 63.
And as Roger said, major gains in FE are obtainable by driving with a fuel-economic style..
2. optional 3.55, or 3.92 (or higher!) Final Drive Ratio FDR reduce your fuel economy,
a loss of ~1 mpg highway for each option above 3.21 is likely
3. OE tires are optimized for many things, including cost (low) and fuel economy (high).
Swapping them for pretty much ANY other tire (unless it was an "ECO" tire) is going to reduce FE.
Generally the more aggressive the tread, the worst the tire is for FE.
Also larger/heavier wheel+tire combo's hurt FE by requiring more energy to accelerate,
but this is much more significant to "city" driving with little impact on 'highway'..
rear cam, Bluetooth/5.0, single CD, tow hooks, rear slider, bedliner, brake controller, IV hitch
Old 01-17-2014, 04:33 PM
wolfman01 wolfman01 is offline
Vehicle: 2013 Ram 1500 QC 4x4
Trim Level: Bighorn Edition
Rep:126
wolfman01 will become famous soon enoughwolfman01 will become famous soon enough
NM is a 75 mph speed limit state right? How fast do you drive? I kept my 2012 to 60, and saw as high as 24.7 mpg in very favorable conditions. Does yours have MDS? If not, you'll still be a tick lower than the MDS equipped engines. Don't idle, don't use drive thrus, don't warm up the truck in the morning before leaving for work. Your mileage will go up doing the above.
2014 Chevy Spark (3k)
2013 Ram 1500 Quad Cab 4x4 Hemi 8 speed (7k)
2004 Saturn ION Redline (9k)
1995 Tiffin Allegro Bay (46k)
1989 Oldsmobile Cutlass Cierra (97k)
Old 01-23-2014, 12:37 AM
Rep:2929
More most excellent advice! ^^^^^^^^^^^^^^^
Old 01-27-2014, 10:40 PM
Captain10's Avatar
Captain10 Captain10 is offline
Vehicle: 2007 Dodge Ram
Captain10 is on a distinguished road
Does warming up the truck in the morning affect MPG that much? I have a 3 mile drive to work so I like to let the truck for 10 minutes before I jump in for my short commute. I got about 250 miles on the last tank before the low fuel light came on which seems a little low to me. Dont really remember what I use to get in my 06 but its the same motor, only difference is a magnaflow exhaust.
35x12.5 Federal Couragia M/T|20x9 Ballistic Jester 0 offset|Bilstein 5100 Maxed|Magnaflow Muffler|BakFlip VP|LED Tailgate Light Bar
Old 01-27-2014, 11:56 PM
Rep:2929
Definitely. Letting it idle eats up fuel and there's no bang for the buck when idling. Short drives are killer on the battery and motor, but idling will kill the mpg.
Old 01-28-2014, 09:38 AM
Captain10's Avatar
Id rather save the battery and motor than the FE. The guy I bought it from had a short commute as well.
Old 01-28-2014, 11:11 PM
Rep:2929
Wise decision, my friend.
