Old 01-16-2014, 01:42 PM
gator9896 gator9896 is offline
Vehicle: 2004 Ram 1500 2011 Ram 1500
Trim Level: Longhorn Crew Cab 4
Rep:15
gator9896 is on a distinguished road
Default Water leaking in from rear window
Noticed the other day while I was driving in the rain that there was alot of water on my headliner in each back corner up top of back seat. Took it to dealer they resealed the entire back sliding window. Checked under headliner for any rust or damage and it was fine. They sprayed water on it for about 5 minutes from a garden hose and it fixed the issiue . Thankfully still under warrenty . Just passing it along. They told me the original seal seperated from the window on each top corner thats were the water was coming in.
Old 01-16-2014, 02:42 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Just FYI.....Have a look at this thread.....A ton of members had issues with their third brake light leaking......
http://www.ramforumz.com/showthread....+light+leaking
Hopefully in your case the issue was solved however just in case it starts again this can assist you....
Ed
Old 01-16-2014, 06:43 PM
Rep:15
Thanks for the heads up. They did check that for me and its sealed . This was my first thought about the leak.
Again Thank you
Old 01-16-2014, 07:36 PM
Chunkem's Avatar
Rep:1637
Again Thank you
Hey no worries at all....Im just glad that you had that issue corrected......
Old 01-19-2014, 05:50 PM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
figured this was another leaking break light thread, first i have read about the rear window leaking.
Old 01-22-2014, 05:46 AM
shostopper17's Avatar
shostopper17 shostopper17 is offline
Vehicle: 2011 Dodge Ram Express
Trim Level: 1500 Express
Rep:54
shostopper17 will become famous soon enough
same happen to me they sealed it and replaced the bulb coast me 5 bucks
Old 01-26-2014, 02:55 AM
Chopper's Avatar
Chopper Chopper is offline
Vehicle: 2011 Ram quadcab
Trim Level: sxt
Color: red
Rep:13
Chopper is on a distinguished road
Send a message via Yahoo to Chopper
Dealership charged me 50 DOLLARS to put a new bulb in the 3rd brakelight told me there was a little moisture that was it. have had problems with the rear window leaking
Old 01-26-2014, 02:33 PM
SShadow1974's Avatar
Vehicle: 2016 Ram 1500 Sport w/RAMBox
Rep:156
Yeah, there is water in my 3rd brake light. When I take it in for it's first oil change they'll be fixing that under warranty.
S S H A D O W
Old 01-30-2014, 12:07 AM
ramman2011 ramman2011 is offline
Vehicle: 2011 ram 1500
Trim Level: Lar
Color: Two tone
ramman2011 is on a distinguished road
I also have this awesome issue. I will be sealing the light better to see if that is the issue
