Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Dodge Ram Decals
Old 01-16-2014, 05:15 PM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
Default CB Install
I'm sure there is already a thread on here but I can't find one with detail - which I need since I'm still learning this stuff...
I'd like to wire my CB (power cable has inline fuses on both the pos and neg) to the fuse box so that when the truck is turned off the cb can't draw power. I want it to only get power in ACC / Running, etc.
I understand how to route the wires through he firewall to the fuse box. Here are already a bunch if wires passing through. But, where exactly do the wires go into the fuse box itself, would I have to use an empty slot? If I use an empty slot do I need to use a fuse there - 20a? Or does the pos get spliced into the ACC wire (where ever that is) and the neg grounded on the frame?
See...I'm lost...
If someone has a guide or can point me to one, I'd appreciate it! Thanks in advance.
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 01-16-2014, 11:04 PM
misfit1981's Avatar
Color: Silver PS2
Rep:45
I'm concerned because i don't want to do a "hack job". Problem is I don't know enough about electrical work to know an apple from an orange. Anyway I just came across this picture. Guy says "here is where I tapped the ignition hot" (image is of a '12 3500 Diesel)
Is something like this "ok" to do? Its probably not the correct spot for my cb to run on the ACC circuit. But, once I find out where the correct spot is, is this method ok to use?
Old 01-22-2014, 12:40 AM
nickb nickb is offline
Vehicle: 2013 Ram 1500 4x4
Rep:17
nickb is on a distinguished road
You will more than likely have to use some fuse that is already tied to ACC power like maybe the fuse for your radio. I would think a 5 or 10 amp fuse should carry the load of a CB since wattage on those is really low so they won't draw too much current.
Old 01-22-2014, 12:42 AM
Rep:17
Just thought of this but one of your cig lighter plugs should be tied to your ignition since it is only hot when key is on might look that one up on your fuse guide and tap into that in your box. Just an idea.
