Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
Old 01-21-2014, 12:23 AM
semlohde's Avatar
semlohde semlohde is offline
Vehicle: 2014 RAM Laramie LongHorn Mega
Trim Level: LaramieLongHorn Mega
Color: bright white
semlohde is on a distinguished road
Got that - Thanks. Shows the manual selection. I misread and thought something showed as the gears changed. I'm thinking that would be useful towing.
Old 01-21-2014, 09:09 AM
Rusty289's Avatar
Rusty289 Rusty289 is offline
Vehicle: 2014 Ram 1500 Crew Cab
Rep:117
Rusty289 will become famous soon enoughRusty289 will become famous soon enough
I have not seen any display that shows the current gear, only the top gear selection when in manual shift mode.
Is there an update that will show me my current gear?? I have been wanting that since I had my 09!
Can anyone confirm this???
If ya can't Dodge it, Ram it!!!
Old 01-21-2014, 10:08 AM
RocketFoot's Avatar
RocketFoot RocketFoot is offline
Vehicle: 2013 Dodge Ram
Color: Western Brown Monotone
Rep:59
RocketFoot will become famous soon enough
The way I understand it is that you need to press the + button until 8 shows on the display and then you will see the current gear to the left of the 8. 8 is displayed as the highest gear you want it to shift to.
Old 01-21-2014, 03:37 PM
ApexCars ApexCars is offline
Vehicle: 2014 Ram 1500 4X4
Color: Maximum steel/silver
Rep:26
ApexCars is on a distinguished road
As soon as I press the +/- buttons on the steering wheel, I see the current gear and the highest selected gear. I shows up right next to the D in the gear selection display at the bottom of the EVIC.
Old 01-22-2014, 10:08 AM
count2 count2 is offline
Trim Level: Big Horn 4x4
Color: Deep Cherry Red
Rep:21
count2 is on a distinguished road
I saw this in the Tips & Tricks thread and tried it out on mine. When I first hit + or - it shows the current gear, then I use + to go up to 8. All I see is that 8, I never see the gear it is currently in. I know some trucks have the transmission with Tip Start, which I do NOT have, was wondering if this feature was tied to that version of the transmission.
Old 01-25-2014, 10:55 PM
swallac2 swallac2 is offline
swallac2 is on a distinguished road
I've noticed when I used the +/- buttons to get the gear display up that the ECO light no longer comes on. I know that ECO is not directly tied to MDS but I'm wondering if putting the transmission into this mode also disables MDS. Its really hard to feel when this thing is in MDS. Which is good since you could clearly tell in my Silverado!
Old 01-26-2014, 12:32 AM
PostalTwo PostalTwo is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Trim Level: sport
Color: maximum steel metalic
Rep:14
PostalTwo is on a distinguished road
tip start is not a transmission feature is for starting with tip start u dont have to hold the key to the start position to continue to crank only have to push to start momentarily and it will continue to crank till it starts
2014 sport hemi 4x4 with 8speed bone stock max steel metallic and love it!
Old 01-27-2014, 09:56 AM
Rep:21
I realize this, but there are 2 versions of the transmission, on your build sheet it will say MAKE or BUY. The ones that say MAKE do not come with tip start. So somehow, the tip start feature is tied to the transmission. My V6 has the 845RE trans and does not have tip start.
Old 01-28-2014, 09:41 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
Here's my cluster.. It's on a '14 Ram 3500 Laramie...
If you look carefully, you'll see it's showing that the transmission has access to all 6 gears but was in 4th gear...
BTW, if you're wondering, it's a Cummins with the Aisin transmission.. I had just filled up about 25 miles before hand... Tow/Haul activated and Exhaust brake on full.
Old 01-28-2014, 09:52 PM
lespaul24 lespaul24 is offline
Vehicle: 2012 Ram Laramie
Trim Level: laramie
Color: blue
lespaul24 is on a distinguished road
I honestly thought they were exactly the same.
