Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > 2014 Dodge Ram Forum
2014 Dodge Ram Forum For specific discussion of the 2014 Dodge Ram!
ZDOG
Old 01-28-2014, 09:59 PM
Pondering Pondering is offline
Vehicle: 2000 Tundra 2007 FJ
Trim Level: Pondering
Color: Pondering
Pondering is on a distinguished road
I test drove a 13 and when I did I flashed thru a display that was showing me the gear I was in.
Old 01-28-2014, 11:24 PM
PostalTwo PostalTwo is offline
Vehicle: 2014 Ram 1500 Crew 4x4
Trim Level: sport
Color: maximum steel metalic
Rep:14
PostalTwo is on a distinguished road
Originally Posted by count2 View Post
I realize this, but there are 2 versions of the transmission, on your build sheet it will say MAKE or BUY. The ones that say MAKE do not come with tip start. So somehow, the tip start feature is tied to the transmission. My V6 has the 845RE trans and does not have tip start.
Thanks I did not know that! I do have buy on my build sheet and the feature to see the current gear.
2014 sport hemi 4x4 with 8speed bone stock max steel metallic and love it!
Old 01-29-2014, 11:50 AM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
I not 100% sure on this, but from what I remember, I thought the ones built by Chrysler had a internal part that was stronger... other then that, I thought they were identical in hardware...
I still don't understand how Tip start would be affected by any auto transmission... Even one that was 10 years old. Autos are basically in neutral, when in Park, as are manual trannies (clutch pushed in). Tip start is just a matter of the ECM cranking the engine for you versus you keeping the key turned....
Old 01-29-2014, 01:45 PM
Claykan Claykan is offline
Vehicle: 2014 Ram Big Horn
Color: Deep Cherry Red
Claykan is on a distinguished road
On page 275 of the User's Manual for the 2014 1500, the premium instrument panel shows both the gear you are in, and the highest gear you want it to be in.
I haven't tried it, but I'm guessing that if you are sitting still, and in neutral, you won't see a current gear, and may have to select "Drive" to see it.
Old 01-29-2014, 08:56 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
my 13 with a v6 has tip start. and my tranny came from Germany. and I have not found a way to show what gear I am currently in only the way to limit it's top gear.
Old 01-30-2014, 12:00 PM
count2 count2 is offline
Trim Level: Big Horn 4x4
Rep:21
count2 is on a distinguished road
I can say for sure, I do not have tip start - I've tried it. I also do not have the indicator of the current gear, it only shows the "high" gear. If you look through the Build and Price or the sales brochure on the Ram, you see Tip Start listed with the 8HP70 but not the 845RE. It may not be a part of the transmission, but for whatever reason they are bundled.
Old 01-30-2014, 07:00 PM
Bushmaster's Avatar
Bushmaster Bushmaster is offline
Trim Level: Outdoorsman 4x4 CC
Color: Bright White Clearcoat
Rep:110
Bushmaster will become famous soon enoughBushmaster will become famous soon enough
Here's my cluster.. It's on a '14 Ram 3500 Laramie...
If you look carefully, you'll see it's showing that the transmission has access to all 6 gears but was in 4th gear...
BTW, if you're wondering, it's a Cummins with the Aisin transmission.. I had just filled up about 25 miles before hand... Tow/Haul activated and Exhaust brake on full.
Wow I wish I could get 57mpg.
Bakflip G2 tonneau cover, SunTek clear wrap complete front end, Trail FX wheel to wheel nerf bars, Huskyliner mudflaps, Weather Tech front floor mats, rear Recon mini lightbar,20% tint front door windows, 5% tint rear door/rear window, Smittybilt Lightbar with 10" Rigid LED lightbar
Old 01-31-2014, 10:35 AM
Rep:62
LOL That's nothing!.. When I'm going down hill, I'm in the 90's... even in tow haul mode with the exhaust brake on..
I guess that's what a diesel will get you.. If you know how to take your foot off the peddle...
On the serious side, I get between 17.5 - 18.5 mpg avg, with this winter blend fuel.. Last fall, when I 1st picked up the truck, I was getting 18.3-20.5mpg avg. I'll get a better idea of how the truck really does, once we get back to summer blended diesel... Winter blend can really kill the mpg, depending on how they mix it to keep it from gelling. I also figure once the motor gets broken in ... at around 20k or 30K miles, I'll probably get a 1mpg bump...
Old 01-31-2014, 02:01 PM
sbarber sbarber is offline
Vehicle: 2014 ram
sbarber is on a distinguished road
I have a 14 blacked out express with 8 speed. I'm guessing that my EVIC is different than a sport or higher end models, I can't see the current gear. Should I be able to?
