Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 01-17-2014, 12:33 PM
ramrod9867's Avatar
ramrod9867 ramrod9867 is offline
Vehicle: 2011 dodge ram
Color: Deep Water Blue Pearlcoat
Rep:33
ramrod9867 is on a distinguished road
Default shift got stuck
It was a snowy day in NY (1 foot with drifts) i got off work put the truck in 4x4 auto and into drive with no problem. Upon getting home i was unable to shift into park i could not get it past reverse. I was worried i didnt know what to do so i left it in neutral with the ebrake on but the next morning it shifted just fine. Anyone else get this problem?
Old 01-17-2014, 02:25 PM
Black Diamond 357's Avatar
Black Diamond 357 Black Diamond 357 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Black Diamond
Rep:25
Black Diamond 357 is on a distinguished road
Snow is getting lodge around the shifter area. It a known issue for you guys living in snowy area.
Old 01-17-2014, 03:48 PM
bran101010 bran101010 is offline
Vehicle: 2011 dodge ram 1500
Trim Level: express
Color: silver
bran101010 is on a distinguished road
My truck doesn't like to go into park sometimes, I just shake the steering wheel and push on it and it will normally go into park.
Old 01-18-2014, 11:06 AM
ramrod9867's Avatar
Rep:33
Yes that snow would of blocked it, it wiggled the steering column and never ever made it park. The new morning i guess the snow melted away and park was working.
Is there anything i can do? I am handy with metal working but not sure what i am looking for to build a case around.
Old 01-19-2014, 05:44 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:724
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
so far, no one has come up with anything to prevent this.
Old 01-21-2014, 10:27 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:470
TransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of lightTransEngineer is a glorious beacon of light
There is now a plastic shield released (that mounts in front of the shift lever on the transmission) to avoid snow packing on the shift lever. This same shield is production on 2014 6-speed trucks, and can be installed on earlier (2010-13 MY) trucks.
The shield is 68166463AA, and it is retained by a single screw (06508224AA) which gets screwed into one of the bosses on the side of the transmission case. The shield has a stub at the top which is inserted into one of the case machining ears, which also locates / retains the shield. List price for the shield is $6.60, and the screw is $1.20.
You'll have to order the shield (and likely the screw also), since there are only 24 shields in stock at the moment, and they're all at the national parts depot in Warren, MI. We have plenty of the screws, but they're almost all at a single national parts depot as well. So your dealer will need to order them.
The shield should bolt onto any gas engine RFE transmission, since the case machining (machining ear and boss) have been unchanged. But the shield is shaped to clear the shifter cable, and I'm not sure whether the location / mounting of the shifter cable has changed over the years. So you may wind up with interference (with the shifter cable) if you try to use it on earlier years.
However, to my knowledge, snow packing on the shift lever has primarily been an issue on 2012-2013 trucks, so I think most owners of earlier vehicles would not need to worry about it.
I should also note that (on 2012-13 trucks, at least) there is a clip holding the shifter cable, that apparently is mounted onto one of the trans bellhousing bolts. The new shield should include a clip feature to hold the cable, so you can remove and discard the bellhousing clip if it causes a problem when installing the shield.
Old 01-21-2014, 01:11 PM
Rep:724
tks trans...........
Old 01-22-2014, 12:50 AM
ramrod9867's Avatar
Rep:33
WOW this is amazing stuff!!!!! Thanks for this information, I will attempt to fix this and reply back soon.
Old 01-24-2014, 11:45 AM
Rep:724
are you going to try the plastic shield ?
