Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 01-17-2014, 12:56 PM
Toon tugr's Avatar
Toon tugr Toon tugr is offline
Vehicle: 2005 cummins & 2010 5.7 Hemi
Trim Level: 2005 & 2010 are SLT
Color: 2010 Silver, 2005 Burgundy / silver
Toon tugr is on a distinguished road
Default Is there a happy medium?
Just installed the kit a bit over a week ago and went with the remote fill / no compressor for simplicity.
Question is why is there no way of attaching the bag to the lower plate?
I am having a tough time finding the happy medium here. I drive primarily rough country roads, about 200 miles a week daily commute to and from work all via rough country roads.
Here is the dilemma I have right now, I keep the bags aired up enough to keep them in contact with the lower plate but if I have just enough in there so they just touch I get a slapping / clapping noise as the rear end jumps over the rough roads as the bag comes away from the lower plate, if I add just enough air to eliminate the noise and keep them in contact enough to avoid this then it feel like I am riding a kick ball down the road, the rear end is continuously bouncing and I installed brand new Bilstein 5100 shocks and struts just a few weeks before, feels like there are no shocks at all on the rear.
Why is there not a snap ring on the guide stud or a stud to bolt it down to keep the bag stretched out and in contact with the bottom plate with low air pressure in the bag?
What am I missing here?
05 Cummins 4x4 QC SB 112k,10 Hemi 4x4 QC SB 60k
sold 02 http://www.youtube.com/watch?v=i3TkO071kTk
Old 01-18-2014, 08:10 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Maybe it has to do with suspension travel. If the truck is lifted on a hoist and full suspension drop is allowed it may tear the bags or bend the brackets ?I am going to put my truck on the hoist one of these days and see how far the suspension dose drop. I have installed Firestone bags on many customers trucks and they are attached top and bottom and they have no problem ? (TLC is the only company that makes bags of this type for the ram) I would like to see how the bags are mounted on the factory air ride suspension. One thing I have been considering doing is pulling the air out of the bags and tying them to the top mount.I pulled my truck out of the heated shop into the MN cold, a few hours later I looked under the truck and the bags had pulled themselves up off the mounts so that is when the idea of tying them up came about. I would just let them down when needed. Maybe there isin't enough clearance to do this ?
Old 01-18-2014, 09:49 AM
Toon tugr's Avatar
The bags are plenty long enough at full axle droop on a hoist to make contact with the lower plates, I have a hoist in my shop and that's how I installed mine. I also have 3/4 inch coil spacers installed under the rear coils and they still had more than enough reach to go yet.
Old 01-18-2014, 08:51 PM
Vehicle: 2012 Ram
Rep:163
Thanks for the info.I guess it may be time to put nuts on the studs that go through the bottom bracket.
Old 01-23-2014, 04:00 PM
Toon tugr's Avatar
Figured the vendors watched their product forums closer but since a week passed with no word from them I sent a PM to TLC John who replied he would check on this with his people.
Old 01-24-2014, 08:15 AM
Vehicle: 2012 Ram
Rep:163
Have you updated the kit with the studs that install in the bottom bolt holes of the bag ? You then drill holes in the bottom plate for these studs to go through to keep the bags in place. The kit dosen't include nuts for the studs, but it dosen't tell you to bolt them down either so you would have to provide those. You replied back to me that the bags are long enough for full suspension drop so I was going to put nuts on the studs to sercure the bags to the lower plate. Then I can run 2psi of air pressure and not get the slapping noise. Haven't done this yet so I can not tell you if it works.
Old 01-29-2014, 01:45 PM
Toon tugr's Avatar
Is there a kit you are referring to or are these studs you are talking about something you found?
I still have not heard anything back from them yet. will send them another PM.
Old 01-29-2014, 05:27 PM
Vehicle: 2012 Ram
Rep:163
Yes it is a kit with template,4 studs and instructions on installation.You may need to call Lola and talk to her.They do not seem to monitor this form.
Old 01-29-2014, 07:10 PM
Toon tugr's Avatar
Why would this not be included with the kit in the first place?
I don't see anything about it on their site, did you have to call to get one and how much extra did they get for th kit?
Old 01-30-2014, 08:00 AM
Vehicle: 2012 Ram
Rep:163
I called Lola and they sent it for free.
