Is there a happy medium? - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 04-08-2014, 05:53 PM
sport14's Avatar
sport14 sport14 is offline
Vehicle: 2014 Ram Sport
sport14 is on a distinguished road
Toon tugr, are you having any issues running the TLC bags nearly empty and bolted down at the bottom? If this doesn't screw up the bags, I'm leaning toward this setup as well.
Old 05-03-2014, 07:47 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Bolted mine down on the bottom but was only able bolt them down with rear stud, a nut on the front stud would not fit because the stud just clears the plate on top of the axle. One trip 50 miles with 3 psi and no load and nothing bad happened.
Old 06-07-2014, 12:32 AM
Toon tugr's Avatar
Toon tugr Toon tugr is offline
Vehicle: 2005 cummins & 2010 5.7 Hemi
Trim Level: 2005 & 2010 are SLT
Color: 2010 Silver, 2005 Burgundy / silver
Toon tugr is on a distinguished road
Best thing I did was remove the aluminum locator pins and bolt them to the lower plate with a single bolt on each side where the locator pin was screwed in, eliminated all my issues. I run them with just a pound or two of pressure in them just to keep them inflated. No issues at all.
05 Cummins 4x4 QC SB 123k,10 Hemi 4x4 QC SB 101k
sold 02 http://www.youtube.com/watch?v=i3TkO071kTk
Old 06-07-2014, 11:10 AM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
I've been running 8psi for 2 days now (only put around 100 miles on) and the ride quality seems as good or better than stock for me. Only raised my back end by 1/2" or so....wondering if having the TGC spacer in my rear coils is making things better?
Old 06-21-2014, 10:04 AM
JGRam81's Avatar
JGRam81 JGRam81 is offline
Vehicle: 2011 Dodge Ram 1500
JGRam81 is on a distinguished road
I sent TLC an email yesterday because I've been having the same damn problem with my locator pin coming out of the bottom plate. At least once a week I have to completely deflate the bags, then while they're reinflating I have to hurry and get underneath with a pry bar to get both of the bags to seat properly before they fill back up. I only go to about 5 PSI when I'm not hauling. The response I received from Lola was to bolt them down with a 3/4"x3/8" bolt and large 3/8" washer. She also told me to run 8-10 PSI instead of 5. Even with Bilstein 5100s set at 2.1 inches in the front, 5 PSI still keeps a 1.5" rake on my truck; I can only imagine what kind of rake I'll have with 8-10 PSI...?
I'm gonna try inflating them to 8 PSI because I'm hesitant to bolt the bags.
Old 06-25-2014, 10:34 AM
Vehicle: 2009
Rep:68
Mine have been the same way, locator pins pop out daily. I contacted Lola and was told it's rare and that someone has this issue. (Doesn't seem that way now, does it? ) No fix was available.. I have been running them without the pins and they seem to be working fine. I like the system and the ride it gives but feel that the design is really lacking and doesn't work. I am a machinist by trade so I will end up voiding my TLC warranty and redesigning how these mount and "locate" at the bottom so that the bags will actually work as described.
