What synthetic oil do you use? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 01-18-2014, 11:13 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Originally Posted by ptesmoke View Post
amsoil signature with matching amsoil filter.
to buddy above, why 0w20? can you explain the benefit from 5-0w?
The 0w20 actually gets up into the engine quicker when you first start up with a cold engine. Once up to operating temperature it's exactly the same viscosity. The 5 in front is the weight only when below normal operating temp.
sales@revelperformance.com
Old 01-18-2014, 01:19 PM
dieselman dieselman is offline
Vehicle: 2013 ram
Trim Level: sport
dieselman is on a distinguished road
Well All my toys get only THE BEST. VALVOLINE FULL SNY.
Old 01-18-2014, 01:43 PM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
Penzoil platinum right here. Does Great!! I did run mobil 1 on all my vehicles but it doesnt meet the Chrysler spec and I didn't want them makin a fuss about my warranty
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 01-18-2014, 07:28 PM
sfstever sfstever is offline
Vehicle: 2013 RAM 1500 LARAMIE CC
Rep:14
sfstever is on a distinguished road
Default What synthetic oil do you use?
im with you dieselman......valvoline synthetic. Been using Valvoline for 22years now.
Old 01-18-2014, 09:10 PM
nickb nickb is offline
Vehicle: 2013 Ram 1500 4x4
Rep:17
nickb is on a distinguished road
Uhh ohh... I have never researched it but Mobil 1 syn doesn't meet Chrysler spec??? Can u elaborate a little on that one.
Old 01-18-2014, 09:37 PM
qflyer qflyer is offline
Vehicle: 2012 Ram 1500
qflyer is on a distinguished road
I've never heard this about M1 5W-20 either...Interested to see a source for this.
Originally Posted by NY Ram 86 View Post
I'm looking to change my oil tomorrow and want to change to a synthetic oil. Any suggestions?
Anyways, I did the first 25K miles or so on whatever filter and semi-syn oil the dealer was using. Last couple changes I've done on my own and used M1 5W-20 with the M1-210 filter. My next change will be Pennzoil Platinum or Ultra if I can find it. I'm trying it simply because it gets such good reviews over at the BITOG forums. Filter, undecided...may try out the Fram Ultra as it has very impressive specs. In reality, both the oil and Fram Ultra/M1 filter are probably overkill even at an 8K oil change interval. I use the higher quality stuff because it ends up costing just a few cents per thousand miles more than the cheaper oils and filters.
If you're doing 3K-5K oil changes, just about any oil and filter will do fine. Start pushing it closer to 10K and you have to buy a bit higher quality stuff. Over 10K and you need to buy the best, and you should probably do a used oil analysis to see exactly how far you can safely go on the oil/filter combo you choose.
Old 01-18-2014, 10:15 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i thought i read somewhere that mobil 1 no longer met Chrysler's standard...but i would still use it!
Old 01-18-2014, 11:03 PM
Well, it appears that even though M1 5W-20 meets API standards, it has not passed the tests required by Chrysler Material Standard MS-6395. Here's a good link to a recent discussion. http://www.bobistheoilguy.com/forums...pics/2629126/2
Looks like the switch to Pennzoil Ultra may be a good idea just to avoid any possible headaches with a warranty claim somewhere down the road.
Old 01-18-2014, 11:27 PM
BigRedRam1500's Avatar
BigRedRam1500 BigRedRam1500 is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Longhorn 4x4
Color: Deep Cherry Red & Gold
Rep:58
BigRedRam1500 will become famous soon enough
Had my first oil change done today at the dealer, OD was at only 1100 miles which is where I wanted first oil change. went with Dino oil this time and have one more free change from dealer, then plan on switching to synthetic...
Old 01-19-2014, 05:45 PM
Rep:17
Wow that blows my mind because Mobil 1 full syn is some of the best "consumer" available syn oil on the market. I know I have heard awesome stuff about amsoil but too me the average consumer I want to be able to get a case of oil off the shelf of my local parts dealer vs having to order something.
