Old 01-17-2014, 10:28 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Default Wiring Off-Road Lights
I'm wiring up KC Driving Slimlites. Pretty simple, but I don't want to splice into the high-beams. I need a switch wire (accessory) in the cab area to connect the switch (white wire)... so that I can operate the lights independently. Anyone know of an easily accessible wire that I can tap in to? This is just for the switch. The lights are powered thru the relay via the battery. Thanks!
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 01-18-2014, 12:05 PM
Rep:262
Crickets... Nobody ever wired up an accessory with a switch wire in the cab?
Old 01-18-2014, 03:19 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
I tapped into the power outlet in my console. I used that connection due to it being switched and I have three switches connected to it for my onboard compressor, horn selector and a switch to open a solenoid to drain my air tank. You can see the switches here: http://www.ramforumz.com/showthread....132797&page=84
Mods: Too many to list
Old 01-18-2014, 04:36 PM
Rep:262
Thanks mrolow! How did you get access to the wire? Does the power outlet just pull out, or did you remove the entire console?
Old 01-18-2014, 05:08 PM
mrolow's Avatar
Rep:132
The chrome ring will come off with a little pulling, it has four clips holding it down. Under the rubber insert in the front tray, there are two screws. The power jack can be unplugged after the upper cover is removed. If you want to drill the holes outside the truck, there are screws under the rubber inserts in the cup holders.
Old 01-18-2014, 06:43 PM
Rep:262
Thanks...........
