Old 01-20-2014, 12:23 AM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
The 24v came out mid 98. Main thing to watch for is the 53 block, and watch the fuel pressure to the VP44 injection pump.
Old 01-20-2014, 09:17 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2826
That is correct, my bad. Yeah 98.5 the 24V was released. I always forget because my work truck is an early 98 with a 12V 5.9.
IG:@briley59
Old 01-20-2014, 04:24 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
The "VP pumps" are a known weak point, but are fairly easy to fix. There is also a problem with certain year blocks being weak. Google "Cummins 53 block" and that will tell you all you need to know as far as the years involved and how to tell if the truck has one.
Old 01-20-2014, 05:15 PM
Rep:326
If you've got the 98 12v quad cab 4x4, that's a very desirable truck. They call it the "Holy Grail" and they tend to go for a few thousand over book if they're nice. I was looking for one, but they're hard to find in good shape.
Old 01-21-2014, 07:07 PM
Bigred74's Avatar
Bigred74 Bigred74 is offline
Vehicle: 1999 Dodge Ram 1500
Rep:258
Bigred74 is a jewel in the roughBigred74 is a jewel in the roughBigred74 is a jewel in the rough
is it better to go for a 12v or 24v? what are the differences in them?
thanks for the input so far guys
*Bedliner paint job, leveling kit, 3'' body lift, 17'' eagle alloy rims series 197, 315/70/17 Nitto Trail Grappler M/T tires, S&B cold air intake, 52mm ported and bored throttle body, Superchips 3865 programmer
Old 01-21-2014, 08:08 PM
Rep:326
Both are desirable for different reasons, although more people like the 12v trucks.
The 12v is all mechanical. No computers or emissions. The injection pump is legendary (P7100). These truck have static timing. There aren't really any flaws except the Killer Dowel Pin. There have been some late 12v trucks with the 53 block. It's rare though. These are stout engines.
Depending on the year and transmission, the 12v had 160, 180, or 215 HP injection pumps.
The 24v has electronic injection, a better flowing head (2 more valves per cylinder), and can be tuned electronically. Also has features like 6 cylinder and 3 cylinder high idle. The VP44 requires at least 10 psi fuel pressure from the lift pump to survive. Also the 53 block.
Here's some 53 block info:
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
There are 2 models of the VP44 injection pumps. Standard output and high output. SO are 235 HP 460 LB FT TQ. HO are 245 HP 505 LB FT TQ. HO pumps are only on 01-02 6 speed manual and fuel hard at low rpm's, but are only good up to about 550 HP. SO pumps are on automatic and 5 speeds and are good for 700+ HP. For max power, a lot of guys chose to swap a P-pump from a 12v.
That's a brief overview. Both engines have advantages and disadvantages. Here's some Killer Dowel Pin info:
http://www.*******************/tech/...s_fatal_flaws/
