Old 01-18-2014, 01:48 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
Default line out converters
im adding a setup/system to my truck. 2 amps , 4 new speakers,4 subs. i dont wanna get into a fortune just to keep the factory head unit. im looking at an audiocontrol lc2i. i only need 2 outputs so i think its ok...any input on this? for what its worth the lc6i isnt too much more..but i dont need 6 outputs.want some feed back from anyone useing one. i have a cheap lineout coverter now and im not impressed with it much at all. for 2 10" mtx sledgehammers on a alpine mrp500 it should hit much better.
2011 Hemi RCSB Sport 4x4
Old 01-20-2014, 04:58 AM
Vehicle: 2011 Ram
Rep:141
anyone? open to suggestions to any of the audio control products. the rockford and jl cleansweep are just way to expensive for me.
Old 01-20-2014, 06:39 AM
wwalker's Avatar
wwalker wwalker is offline
Vehicle: 2014 Dodge Ram
Trim Level: 1500 Black Edition
wwalker is on a distinguished road
What kind of sub enclosures are you using? That makes a HUGE difference. It did for me. I finally matched the recommended ported box volume that the sub manufacturer recommended, and wow.
I'm using a Scosche LOC that I got from Wal-Mart, and it works great for my application.
Your subs are probably MTX MZS1004 models. MTX recommends:
Sealed Box: 0.75 cu. ft. each
Ported Box: 1.25 cu. ft. each
I would make sure that your box(es) meet MTX recommended volume. If not, then it doesn't matter what you do - your subs will not perform like they should.
I had my single 12 in a box that was smaller than the mfr. recommended. I just picked up a ported Probox, and it made a gigantic difference. I'm running only 200 watts, but it shakes all my mirrors if I want it to.
2014 Black Edition Single Cab Hemi 2WD Mods: Flowmaster Super 44, JBL GT5-12 + Probox
Old 01-20-2014, 10:03 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is online now
Vehicle: 2012 Ram 1500 CC
Rep:264
I'm using the Audiocontrol lc2i and it is awesome. It has been in for awhile now and does a fantastic job. No static or restricted noises with it. I used +/- from one rear speaker into the (left) input on the unit. This is where the feature for the GTO is. If you want to use the unit as a remote turn on for the amp instead of running a separate remote wire to a keyed 12v source. This info was straight from Audiocontrol and works flawlessly for me. It is a little tricky to set it up, but follow the instructions and it is sweet. Check out my thread I did awhile back http://ramforumz.com/showthread.php?t=142272
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 01-20-2014, 05:52 PM
Vehicle: 2011 Ram
Rep:141
thank you just what i wanted.....i have mtx thunder tc510's ..the red sledgehamemrs. yes its .75 sealed which i have...well close.. its .8 ft box so minus the sub displacement, its pretty close...dont get me wrong they pound good, just not as i expected. that issue will be resolved with 4 old school kickers
Old 01-28-2014, 08:27 PM
Vehicle: 2011 Ram
Rep:141
so scratch that idea, i bought a kenwood ddx 470 , nothing fancy but it has what i want, plus 4 volt preouts...ill have amps driving the speakers so its a non issue, i just wanted to keep my steering wheel controls (pac harness), bluetooth and back up cam....now i gotta figure out how to mod the backup cam to work with this.i like how an aftermarket deck has much more expandability...plus ill sell the factory nav and offset the cost some.the pac hanress has a reverse wire so i just need to mod the input...any help would be great
Old 01-29-2014, 12:54 AM
Trackstand's Avatar
Trackstand Trackstand is offline
Vehicle: 2013 Ram 2500 CC LB 4X4
Rep:73
Trackstand will become famous soon enough
Newf. Trackstand from FS here also.
Old 01-29-2014, 04:59 AM
Vehicle: 2011 Ram
Rep:141
wha? you kinda got me lost
Old 01-29-2014, 12:16 PM
Trackstand's Avatar
Rep:73
Thought You were someone else from another forum. my bad
Old 01-30-2014, 06:44 PM
Vehicle: 2011 Ram
Rep:141
ahh very well...explains it
