New 2012 Power Wagon Owner... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 01-19-2014, 11:44 AM
armyrgr's Avatar
armyrgr armyrgr is offline
Vehicle: 2012 Power Wagon
Trim Level: Power Wagon
Color: Grey
armyrgr is on a distinguished road
Default New 2012 Power Wagon Owner...
Hey guys, just wanted to share my excitement with everyone and learn a few things. I just picked up a 2012 Power Wagon with 23,000 miles on it. I need to know what truck specifications do you use to order parts for it? Do you just tell the parts store or click on the website for a 2500? How does it work? Because I don't see the option on websites for Power Wagon. I'd like to get some 3 step running boards on it, and brush guard, and a black toolbox. Any help in the right direction would be greatly appreciated.
I'd also like to look into getting different tires without having to do anything. Something a little bigger than the stock BFG's.
And as far as the locker switches on the dash. I haven't read thru the owners manual completely. Can someone explain to me what that is for. Obviously I know its to lock the front and rear but when can I use it and when can't I? Does the light stay on when it's engaged/disengaged or does it just flash?
Thanks in advance guys, Eddie.
Old 01-19-2014, 12:35 PM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
As for the suspension, its mostly just standard 2500HD (gas). The springs and shocks are really the only difference. The front are 2" taller than standard and the rears use factory shims (blocks) for 2" lift. You can shop around for any 2500HD kit, just remember to subtract 2" from whatever the advertised lift height is. I.E. a 3" lift for a 2500 Gas will actually only give you 1" (assuming you replace the factory rear blocks with whatever comes in the kit).
Several companies make the 3 step boards you are looking for, I have the N-Fab steps as I like their construction better.
The locker and sway bar switches on the dash do just that, lock the front and rear axles. In factory configuration they only function when in 4Low. AS for when you should use the locker, that's sort of on you. I would suggest trying whatever obstacle it is in 4 Low first and then if you cant make it use the lockers. The light will flash on the dash until the lockers engage then it will go steady. it will go out once they are disengaged.
Hope all that helps.
Just Got it, Give me time!
Old 01-19-2014, 05:01 PM
armyrgr's Avatar
Color: Grey
Thanks man. Yes that helps. When you order parts what do you select. Dodge ram 2500 crew cab with what bed? I know its not the long bed but is it the 6'3 or the short 5' something?
Old 01-19-2014, 05:52 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Hey congrats on the new truck. Post some pics when you get a chance.
Ed
Old 01-19-2014, 06:06 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Rep:26
06PowerWagon is on a distinguished road
Congrats on the Power Wagon you will never want anything else to drive once you start driving your PW... Start posting pictures when you can
and Please HAVE FUN GETTING IT DIRTY AND MUDDY....and you will have a blast pulling yourself out of the mud when your stuck
Smile even if its a little creepy
Old 01-19-2014, 06:18 PM
Color: Granite
Rep:286
Really the cab size and bed size only matter when ordering parts for the cab or bed (steps, toneau, etc). The suspension components are the same. theoretically the spring rate should change, and some of the higher end companies will account for this, most will simply have a diesel spring and a gas spring for their respective kits (diesel is about 800lbs heavier in the front). As for the control arms, steering linkage, etc, its all the same.
If you have a Power Wagon you should have the 6'6" (66") bed unless something has changed I am not aware of.
Old 01-19-2014, 08:11 PM
armyrgr's Avatar
Color: Grey
Here you go guys... when ordering seat covers with these bench seats, which option do I need to select( I don't know what seats are in it!!!)
Old 01-19-2014, 08:13 PM
Color: Granite
Rep:286
40/20/40 split bench.
armyrgr's Avatar
Color: Grey
Also, what mods or add ons have you guys done to the 5.7 to increase power and fuel mileage? Cold air intake, exhaust, programmer, headers???
Old 01-19-2014, 08:14 PM
armyrgr's Avatar
Color: Grey
Thanks brother. And for the rear seats? Select the option with the arm rest since it has that pull down/out arm rest in the middle?
