Old 01-19-2014, 10:12 PM
aaronmiiller aaronmiiller is offline
Vehicle: 2006 Dodge Ram
Trim Level: Big Horn SLT
Color: Inferno Red
aaronmiiller is on a distinguished road
Default new waterpump, new stat, still overheating
About 8 months ago my water pump started leaking so i hit and the thermostat replaced. All of a sudden my temperature gauge is acting erratic, so i changed the thermostat. Didn't fix it. I noticed a coolant leak in my driveway and checked my reservoir and sure enough, just below fill line, so i filled it up, of coarse that hasn't fixed it. Anyone got any ideas?
Old 01-20-2014, 02:27 AM
jwsmitty1989's Avatar
jwsmitty1989 jwsmitty1989 is offline
Vehicle: 2002 4x4 quad cab 1500 slt
Trim Level: Sport (going to mod)
Color: Big Red
jwsmitty1989 is on a distinguished road
Send a message via Skype™ to jwsmitty1989
Just had that happen to me last week, it ended up being my radiator, I replaced the radiator and got a new cap for it and my reservoir tank and it works like clock work.
~Smitty~North County San Diego~
Old 01-20-2014, 08:08 AM
Color: Inferno Red
Thanks man, that at least gives me somewhere to look.
Old 01-20-2014, 10:31 AM
iveyusmc iveyusmc is offline
Vehicle: 2006 Ram 1500
Trim Level: Texas Edition
Rep:12
iveyusmc is on a distinguished road
replace the cap if it's still overheating there might be air in the coolant system. With engine COLD jack up the front of the truck and take the cap off. Start it let it come up to temp. I squeze the upper hose from time to time to make sure there is no air bubbles. I did this after I replaced my waterpump, t-stat, cap and new fluid. Never had a problem since. The only other thing I can think of is the t-stat from what im told the little round piece the rattles that's almost on the outside (sorry I don't know the name) needs to be on top in the 12 oclock position for whatever reason. Let me know if any of this helps and good luck!
Old 01-20-2014, 01:34 PM
Color: Inferno Red
Thanks, I'll certainly try it. I'm just wondering why i have a coolant leak I'm my driveway tho. Air in the system doesn't explain that.
Old 01-20-2014, 04:08 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Better hope you don't have a blown/cracked head.....
Old 01-20-2014, 05:04 PM
Color: Inferno Red
Just got a chance to check it out, i didn't even think to check the radiator until just now, the thing was bone dry!!! I filled it up and turned the truck on, it took about a half gallon until it finally stopped taking any. I had to open the cap after i got it hot, tons of air came out. I noticed the upper hose had no fluid in it. Let the truck cool down and it took another half gallon, almost immediately started blowing hot air and the temp is staying between 200-206 now. I'm guessing i had an air lock?
Old 01-20-2014, 07:01 PM
Rep:12
keep it running with the cap off and when the t-stat opens the coolant level will drop. can you trace back where the coolant is leaking from?
Old 01-26-2014, 10:35 PM
Haro Haro is offline
Vehicle: 2005 Dodge Ram
Haro is on a distinguished road
If its still leaking you could always pressure test it and find the leak that way instead of guessing, and with the cap off the rad and the engine running check for constant bubbles if thats the case it could be a head gasket or cracked cylinder,
Old 04-07-2014, 12:36 PM
btaylor1184 btaylor1184 is offline
Vehicle: 03 ram 5.9l
Color: Gold
btaylor1184 is on a distinguished road
also check the clutch fan! I did the whole water pump/ thermostat dance and still overheating. It was odd sometimes i did and other times it wouldn't. I changed clutch fan and BOOM problem fixed!
