Old 01-21-2014, 05:12 AM
Cale Cale is offline
Vehicle: 2006 Dodge Ram 5.7 4x4 MegaCab
Cale is on a distinguished road
Default Towing a 6,250 LB boat with 1500
I have an 06 4x4 Megacab with the 5.7L Auto and 325/65/18s... My mother has a 28.5 foot cruiser boat that specs at 6250lbs... curious as to how my truck (mainly tranny) would hold up on a 250 mile haul to Table Rock come summer. Typically it stays in the water and if it gets pulled out itd be drug around with her 01 Cummins but we would end up putting her Cummins under the 30' 10500lb 5th wheel rv for the trip.
Also, where is the best place and what am i looking at for a good inexpensive tranny cooler and are they easy to install?
Thanks, Cale
Old 01-21-2014, 05:16 AM
... also, it doesnt have much tongue weight as most of the weight is back on the triple axles and has a long trailer tongue. However it does had a 10' beam (requiring permits) and curious where the best place is to order tow mirrors the cheapest?
Old 01-21-2014, 07:58 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Your truck most likely already has a trans cooler. You can upgrade to the HD cooler which a lot of 3rd gen guys do, it's a direct swap. I don't know the details, you can search for more.
I would think you're truck would be ok. My 4.7L is rated to tow somewhere around 7,000 lbs. I'm sure your hemi is rated for more. I've towed 5,000ish up about 2000 miles and it was fine. I've towed more over short distances without issues as well.
The transmission will hold up fine. The only thing I'd watch for is if you are on steep grades for long periods of time watch engine and trans temps. Mine did get very hot climbing the mountains with 5000lbs. There were periods where I was holding ~half pedal for about 10 minutes straight.
Sean
Old 01-21-2014, 08:05 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
1500 mega cab would have about an 8500# GVWR, so the towing cap would be somewhere more than that. They are a 1500 badge on a 2500 truck. I wouldn't hesitate to tow that. Just have to use common sense when towing anything that big and heavy
"I don't care to hear what your ideas are, mine are better"
Old 01-21-2014, 01:13 PM
Alrighty. Yes I have noticed it seems to be a 1500 sticker on the side for no reason. It's apparent that's it's a 2500 under that skirt. Is there anyway to find out if mine already has the HD cooler? And what's the difference in the 1500 tranny and 2500 and which one would I have? Truck has 130k and I know Dodge hasn't been reputable on their trannys when they get high mileage.
For a living I pull two 45' semi trailers at the same time full of beer grossing 80-100k depending on the season. Slow and easy does it with this big ol boat.
Old 01-21-2014, 01:19 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
Yeah, if you look at your axles and brakes, your truck is a 3/4 ton. Depending on the year, the Megacabs were badged as a 1500 or a 2500. I know in that year truck, the transmission would be a 48RE if it had a Cummins in it, but I'm not sure what would be in it with the Hemi. The 48RE is pretty stout and is usually only a problem when people start adding a lot of torque with the Cummins.
I don't know for a fact that your truck has a big tranny cooler, but I bet it does. You should be able to see it out in front of the radiator, but it might be hidden behind the AC condenser. Either way I wouldn't be afraid to tow that boat with your truck, just make sure it has some kind of trailer brakes on it.
Old 01-21-2014, 01:52 PM
snrusnak's Avatar
Rep:1385
Post a pic of your cooler, trace the lines from the transmission and see where they go.
I'm not sure if your megacab "1500" is really a 2500, but the 1500's have a 545rfe transmission(good transmission, not like the bad rep older ones), and the 2500's have a 66rfe(even better transmission). The poster above me called out an older transmission. I'm not sure what year the 66rfe went in to use but I would think in 06 they were in use in the 2500s. I know for sure that the 545rfe was used in 06 in the 1500s. The later diesels used a 68rfe(again not sure what year that started).
Sean
Old 01-21-2014, 02:26 PM
Rep:130
1500 mega cab is a LD 2500. 8500 GVW, 8 bolt hubs, AAM 10.5 out back, and AAM 9.25 front
I think they used the 45Rfe iirc.
Old 01-21-2014, 03:15 PM
I will post a pic of the cooler in a bit when i get back to the truck. in the meantime i emailed Dodge regarding my build specs and they are as follows:
Vehicle Description DODGE RAM 1500 SLT MEGA CAB 4X4
Model Year 2006
Body Model DH 6 H 81
Color PW7A- Bright White Clear Coat
Sales Code Description
*AJ Cloth Bucket Seats
-D5 Med Slate Gray
ADB Protection Group
AHC Trailer Tow Group
APAS Monotone Paint
A85P Mutually Exclusive Package
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CACP Low Back Bucket Seats
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Floor Covering Carpet
CLES Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUSS Overhead Console w/Trip Computer
CU3S Behind the Seat Storage / Bin
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DH3S Elec Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle
DMES 3.73 Rear Axle Ratio
DRWS 10.50 Rear Axle
DSA Anti-Spin Differential Rear Axle
EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine
GACS Tinted Glass Windows
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JTHP Power 6-Way Driver Seat
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LNJ Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Air Close Out Panel
NAA Federal Emissions
NBKP EVAP Control System
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCS Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBES Power Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TT5 LT265/70R17E OWL On/Off Rd Tires
TZGP BF Goodrich Brand Tires
WF1S 17" Steel Spare Wheel
WGSS 17X8.0 Steel Chrome Clad Wheels
WLYC All Steel Wheels
WMJP Center Hub
XA8S Non Adjustable Pedals
XBSS Pickup Box
XCZP Toluca Painted Cargo Box
XEAP Tow Hooks
XEFP Transfer Case Skid Plate Shield
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XJL Front Hood Protection Shield
YAAS Build To U.S. Mkt. Specifications
Our records indicate that the following recall campaigns have not been
performed by an authorized dealer:
Recall # Description Type
Date Issued
H46 STEERING LINKAGE SAFETY
04/27/2009
N62 LEFT OUTER TIE ROD ASSEMBLY SAFETY 12/13/2013
What is the steering linkage safety? and good thing I just found out about the tie rod today lol I just replaced all 4 with Moog this Saturday.
Also Its looking like the gross weight on the boat will be 7200-ish with the trailer. the boat is 6250 all by its self and the trailer does indeed have trailer brakes intergraded in the hitch. More pressure = more braking
Old 01-21-2014, 03:26 PM
snrusnak's Avatar
Rep:1385
You have the 545rfe transmission.
Most likely has an oil cooler, and probably the larger one.
Sean
