Old 01-21-2014, 03:44 PM
Cale Cale is offline
Vehicle: 2006 Dodge Ram 5.7 4x4 MegaCab
Cale is on a distinguished road
AHC? Im lost on most of the abbreviations
Old 01-21-2014, 03:52 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That's just a code the manufacturer uses, I have no idea what it means. But it's the code for "Trailer Tow Group" off your build sheet. I'm assuming that option includes something like hitch, wiring connections, trans cooler, etc. Just guessing. That and the fact it's a HD 1500 or LD 2500 (whatever you want to call it), it probably has a trans cooler, and maybe the big one.
Read up:
http:// www. dodge talk .com/forums/showthread.php?t=308705
(remove the spaces)
Sean
Old 01-21-2014, 03:54 PM
Will do... thanks
Old 01-21-2014, 04:04 PM
good read! Im curious to see what mine is now!
Old 01-21-2014, 04:19 PM
Rep:2664
tow rating is 8,150 with the 3.73 axle ratio
here is more from Chrysler
http://www.media.chrysler.com/dcxms/...gaCabSpecs.pdf
ALLPAR did a write up on what they thought of this Ram Laramie 5.7 with the 4.11 axles
http://www.allpar.com/reviews/2006/ram-megacab.html
Old 01-21-2014, 04:37 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:228
A couple of tips. You probably have the cool tow mirrors. Most people know about them but some people don't. If you grab the lower inside corner of the and tip it up and out, they are in the tow mode and stick out further.
Also, with that trailer brake system, backing up a steep hill will cause the brakes to be on, which can be a problem, but pretty rare. Some systems have a place to insert a pin to disable the brakes for this situation.
Old 01-21-2014, 04:56 PM
No, no super cool ghost trailer mirrors... Yet.
And yes it does have a pin.
I'll be about 7200-7500ish with the trailer so I'll be cutting it close with 8100
Old 01-21-2014, 05:08 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
I towed that much about that same distance with no problems. I have the 5.7 with 545 six speed. I used tow haul the whole way but my temps were fine. Heres my thread on the experience. I have a 3:55 open diff as well.
http://www.ramforumz.com/showthread.php?t=118387
Old 01-21-2014, 05:16 PM
Man that's crazy. Moms boat looks IDENTICAL to that one. Hers is the 2855 though. Roughly 500lbs more I think and she bought it with the triple axle. Good to know u had a good experience with an identical boat.
Old 01-21-2014, 05:59 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Yup, I did this as a favour for a friend and was thankful I had no issues with it. It towed beautifully but you definitely need tow/haul and it will drink the gas The biggest thing that I remember is that I was always on the gas to keep it all rolling and my rear view mirror was all boat.
