2013 Ram Key Fob Stuck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 01-21-2014, 08:51 PM
D-Dub's Avatar
D-Dub D-Dub is offline
Vehicle: 2013 Dodge Ram
D-Dub is on a distinguished road
Default 2013 Ram Key Fob Stuck
I searched and found a few posts on this, but none fixed the problem, but i did end up getting the key out...
Drove home, parked, and the key wouldn't come out. Tried starting and shifting from park to drive then back to park and all the other ideas that were posted.
I ended up backing up slowly down the road and then without being fully stopped, I put it in park, so as to kind of rock it. Now when i say "not fully stopped", I don't mean 10 mph, I stepped on the brakes until it was at a snail's pace roll, then put it in park.
I have a 2013 with a pentastar with just under 900 miles, with the rotary shifter knob.
I think it didn't seat well in park and wouldn't release the key so by slowly rolling and going into park it "clicked" enough to release the key.
Just thought I'd post as i see this has happened to others.
Old 01-22-2014, 05:26 AM
Silvercreek's Avatar
Silvercreek Silvercreek is offline
Vehicle: 2013 Laramie
Trim Level: Longhorn Crew Cab
Color: White/Gold
Rep:487
Silvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of lightSilvercreek is a glorious beacon of light
I think I would let the service department at the dealer fix that.
"One Small Step For Man, One Giant Leap For RAM Fans"
4th Generation - 2013 RAM Laramie Longhorn
*** US Army Retired - 11B40 - 1964/'85 ***
Old 01-22-2014, 09:05 AM
D-Dub's Avatar
I am going to see if it happens again, I drove it this morning and had no issues, hopefully it was just a one time thing, but if it does happen again, it'll definitely be headed back to get looked at.
Old 01-22-2014, 09:56 AM
grossie's Avatar
grossie grossie is offline
Vehicle: 2013 Ram
Trim Level: Tradesman
Color: Mineral Gray
grossie is on a distinguished road
Exclamation 2013 keyfob stuck
I just picked up my Ram at the end of the year. I was having trouble removing the keyfob multiple times. I finally settled on switching where I grab the fob. I'm not sure if that would help at all in your case, but I thought I would mention it. I now remove the fob by grabbing it on the narrow sides (90 degrees perpendicular from the front face in both directions).
I'll admit that doesn't seem like I should have to do that, so I'll be watching to see what you find out.
Old 01-22-2014, 10:03 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Definitely a problem with the park position interlock switch. I would have that taken care of while you have warranty. Probably just an adjustment.
sales@revelperformance.com
Old 01-22-2014, 10:23 AM
GrayhemiST GrayhemiST is offline
Vehicle: 2012 Ram Hemi Regular Cab
Color: Mineral Gray
Rep:277
GrayhemiST is a jewel in the roughGrayhemiST is a jewel in the roughGrayhemiST is a jewel in the rough
Happens in the 2012 models as well with the column gear shift.
Old 01-22-2014, 11:00 AM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2015 Ram Bighorn
Trim Level: Bighorn
Rep:110
Graygoose will become famous soon enoughGraygoose will become famous soon enough
yup, when mine does it, I back up, pull forward again, wait a second before I put in park...usually fixes it
2015 Crew Cab Bighorn
Old 01-22-2014, 11:35 AM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Yeah I have heard of this issue as well......I would still take it in to your dealer.....Get warranty to look after it.....
Old 01-23-2014, 02:24 PM
D-Dub's Avatar
Just happened again....heading to dealer. Worst part is it stays in acc mode, so the battery will drain if I just left it.....
Old 01-24-2014, 11:16 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:782
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
want to know what the dealer has to say.......
