Old 01-21-2014, 09:20 PM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
Default Wheel Adapter length to clear the studs
What is the smallest wheel adapter I can get to clear the studs so I dont have to shave them?
Thanks
Steven
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
Old 01-22-2014, 11:16 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Hope Gingy36 doesn't mind me stealing his pic here. These are BORA 1.5'' wheel adapters. As you can see, the stock studs still stick out a little and he had to shave them. I would safely say the 2'' adapters would work without modification to the stock studs. The 1.75" would be really close and you might still have to shave a thread or two off. Don't know for certain though. This is on the rear of his truck. 2012 model.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 01-22-2014, 01:59 PM
mygt8a4re's Avatar
mygt8a4re mygt8a4re is offline
mygt8a4re is on a distinguished road
Not in all cases but alot of wheels have an opening on the face of the wheel hub where the studs can sit w/o cutting them. Obviously depends on the wheel your opting to use......
here is an example (ignore the text in the pic):
MYGT8A4RE = My GT Ate A Ferrari, been using that screen name for years....
Old 01-22-2014, 07:02 PM
BlownGP's Avatar
Rep:15
Man, 2" would push the wheels I want to far out.. Damn, I need to look at the back of the rims and see if I have those holes.
Thanks for the pic. That is great.
Old 01-22-2014, 07:16 PM
mygt8a4re's Avatar
Anytime....you would really have to work between the possible offsets available and the width of the adapters. In cases with adapters your most likely going to add 1.0" or more so you can always opt to add fender flares to cover the adapter width (to an extent). Then adjust the offset according to where you want your wheels to sit in relation to the fender.
Tell me what your trying to do and let me see if I can figure out a combination. Wheel diameter/width/offset/where you want the wheels to sit/tire size....
