Old 01-22-2014, 02:35 PM
Laser Laser is offline
Vehicle: 2012 Dodge Ram
Laser is on a distinguished road
Default Replacing stock radio
If I want to pull out the RES stereo that came with my Big Horn, are there any well-illustrated instructions for getting the cover panel off without damaging it? I'm assuming this is not an Alpine radio, so choosing an alternate brand replacement so I can get Bluetooth/hands-free cellphone use.
Old 01-23-2014, 03:49 AM
Kelevra's Avatar
Kelevra Kelevra is offline
Rep:91
Kelevra will become famous soon enough
IIRC there were just 2 screws at the top of the bezel (where it says RAM) under the rubber mat, remove those and gently tug, comes right off with ease.
Old 01-23-2014, 04:08 AM
Rep:2640
unless you have an 115Vac outlet, then you pop off the outer cover & remove a screw hidden behind there
you can find compatible radios on the CRUTCHFIELD website
2009 thru 2012 dashes are all the same
Old 01-28-2014, 02:30 PM
bluebird29 bluebird29 is offline
Vehicle: 2007 Dodge Ram
Color: Blue
bluebird29 is on a distinguished road
Two screws in the bottom just over cup holder and pry from bottom corners up
